Hi, I am using AT89C2051 controller and keilµvision4 Evaluation IDE. i am able to download hex file for .asm but not able to downlaod hex file for .C file. Using external programmer it shows verify failed at Byte 2, not even small toogle .C code hex file able to download.
I have tried by changing the settings in keil but no result. Did any one faced this type of issue please help me to solve this issue.
Thanks in advance
If so, did you read the limitations carefully?
If I remember correctly, the 2051 only has 1K memory, so you cannot use it with the evaluation version. See here: http://www.keil.com/demo/limits.asp
