Hi
The combination of C51 V9.00/ V9.01 and the SiLabs uVision Driver V3.21 dosn't work properly. We use a C8051F124 with bank switching. After upgrading to the above described IDE version, we coulnd't set breakpoints ,in other banks than the common one. Today we got a new SiC8051F.dll from SiLabs, which fix this problem. As SiLabs toled, not all instalation seems to show this problem.
Regards
Raphael
as seen here and in the SIlabs forum Keil and SILabs are notorious for being "out of synch" most of the time.
If you have a combo that works and absolutotally can not manage two entries on your taskbar (IDEiocy) then be VERY careful to ALWAYS be able to go back.
The simple solution is to do all development with Keil and all loading and debugging with a freestanding SILabs IDE
This is an automated e-mail. Please do not reply to this message.
You have successfully posted "RE: C51 V9.00/V9.01 and SiLabs uV3/4 Driver V3.21" to http://www.keil.com/forum/docs/thread16497.asp#msg85504
Click on the above link to display this forum thread in your browser. You may click on the following link to go directly to the Keil Discussion Forum web site:
Best regards, Keil, An ARM Company
Keil, An Arm Company 1501 10th Street, Suite 110 Plano, Texas 75074 USA Phone: +1 972-312-1107 FAX: +1 972-312-1159 http://www.keil.com/
IMPORTANT NOTICE: The contents of this email and any attachments are confidential and may also be privileged. If you are not the named recipient, please notify the sender immediately and do not disclose the contents to any other person, use it for any purpose, or store or copy the information in any medium.
Why did you post that??!
