undef handler
Hi all,
If the processor tries to go back from the test() function to the main() function, the program counter gets always the wrong address - so that an undef handler occurs.... (processor is searching for an programm code in the sdram...). The whole programm is stored in an external nor flash device (0x10000000).
void test(void)
   //do some stuff...
   return;
void main(void)
   test();
The user stack size is 0x800. That's a short part of the disassembly where the jump to the sdram occurs (the next step after 0x100012D4).
According to the map file, the function test() is using the memory space until 0x1000012D8 and the next function starts at 0x100001304. I'm not sure about the space within these two points? All these values are also stored in the nor flash device...
   522: return;
0x100012C8  E7980185  LDR       R0,[R8,R5,LSL #3]
0x100012CC  E3C00001  BIC       R0,R0,#0x00000001
0x100012D0  E7880185  STR       R0,[R8,R5,LSL #3]
   523: }
0x100012D4  E8BD8FF8  LDMIA     R13!,{R3-R11,PC}
0x100012D8  544F5250  DD        0x544F5250
0x100012DC  0050495F  DD        0x0050495F
0x100012E0  0A50490A  DD        0x0A50490A
0x100012E4  00000000  DD        0x00000000
0x100012E8  606E6F64  DD        0x606E6F64
0x100012EC  6E6B2074  DD        0x6E6B2074
0x100012F0  7420776F  DD        0x7420776F
0x100012F4  20736968  DD        0x20736968
0x100012F8  6B636170  DD        0x6B636170
0x100012FC  000A7465  DD        0x000A7465
0x10001300  68746520  DD        0x68746520
0x10001304  00000020  DD        0x00000020
    39:                 pbuf->hdr->flag = used;
best regards
Howard
  • Too many questions, and all of them are answered in the ARM Architecture Reference Manual.
    I have no knowledge of the AIC, so I'm afraid my advice could be completely wrong. All I know is that with the startup file you presented, you'll definitely overflow the Supervisor mode stack. That could explain all your troubles.
  • All I know is that with the startup file you presented, you'll definitely overflow the Supervisor mode stack. That could explain all your troubles.
    Could you please tell me which configuration I have to made to avoid supervisor mode stack overflow?
    ; Branch to interrupt handler in User mode */
            MSR     CPSR_c, #ARM_MODE_USER
            STMFD   sp!, {r1-r4, r12, lr}
            MOV     lr, pc
            BX      r0
            LDMIA   sp!, {r1-r4, r12, lr}
            MSR     CPSR_c, #ARM_MODE_IRQ | I_BIT
    Howard
  • This is exactly what I would try first. Of course, the problem could be caused by something completely unrelated to this...
  • Hi Howard,
    ; Exception Vectors
    Vectors
                    LDR     pc,=resetHandler
                    LDR     PC,Undef_Addr
                    LDR     PC,SWI_Addr
                    LDR     PC,PAbt_Addr
                    LDR     PC,DAbt_Addr
                    Where is the Reserved Vector?
                    LDR     PC,[PC,#-0xF20] ; Vector From AIC_IVR
                    LDR     PC,[PC,#-0xF20] ; Vector From AIC_FVR
    Reset_Addr      DCD     resetHandler
    Undef_Addr      DCD     undefVector
    SWI_Addr        DCD     swiVector
    PAbt_Addr       DCD     prefetchAbortVector
    DAbt_Addr       DCD     dataAbortVector
                    DCD     0               ; Reserved Address
    IRQ_Addr        DCD     irqVector
    FIQ_Addr        DCD     fiqVector
    Did you delete anything here?
    You should have 8 exception vectors here, but I only see 7.
  • Hi Howard,
    Mmmmm........
    For me, I choose to use the startup file from KEIL, because I am using KEIL's toolchain. And, I prefer not to change anything in the startup file. It is danger for me.
  • You're definitely right, but the Keil startup file fails if you try to boot from an external flash device. It only works when the programm starts from the internal ram or the external sdram.
    The initialization of the processor is a little bit different depending on the source to boot.
    The reserve vector should be available in the startup file above. The only thing which is different - comparing the map file using Keil startup and atmel startup is that the dataAbortVector get 8byte instead of 4byte as all the other vectors.
    VECTOR                                   0x10000000   Section      168  copy of board_cstartup_keil.o(VECTOR)
        undefVector                              0x1000003c   ARM Code       0  copy of board_cstartup_keil.o(VECTOR)
        swiVector                                0x10000040   ARM Code       0  copy of board_cstartup_keil.o(VECTOR)
        prefetchAbortVector                      0x10000044   ARM Code       0  copy of board_cstartup_keil.o(VECTOR)
        dataAbortVector                          0x10000048   ARM Code       0  copy of board_cstartup_keil.o(VECTOR)
        irqVector                                0x10000050   ARM Code       0  copy of board_cstartup_keil.o(VECTOR)
        fiqVector                                0x10000054   ARM Code       0  copy of board_cstartup_keil.o(VECTOR)
        !!!main                                  0x100000a8   Section        8  __main.o(!!!main)
    best regards
    Howard
  • Hi Howard,
    Are you using an AT91SAM9263, and booting from the NOR-Flash?
    Vectors
                    LDR     PC,Undef_Addr
                    LDR     PC,SWI_Addr
                    LDR     PC,PAbt_Addr
                    LDR     PC,DAbt_Addr
                    NOP
    Please add an "NOP" there, and give it a try.
    (It seems some solutions for AT91SAM9263 are made by GNU toolchain.)
  • Are you using an AT91SAM9263, and booting from the NOR-Flash?
    You are right - are you also using one of the atmel controllers?
    The problem changed; now the processor is able to call the main function from the test2function() once; if I try the same code a second time, it fails.... the test2function is always called if there was an interrupt. So maybe there is something wrong with my interrupt handler in the startup file....
    Right, atmel use the GNU toolchain to compile their boards.
    best regards
    Howard
  • I'm not alone with that problem...
    I will try to use the keil startup file together with my lowlevelinit function. So that the only difference between the original keil file and my startup file will be shown below.
    ; Reset Handler
                    EXPORT  Reset_Handler
                   IMPORT  LowLevelInit
    Reset_Handler
                    ; Set pc to actual code location (i.e. not in remap zone)
                LDR     pc, =label
                    NOP
    label
                    ; Set up temporary stack (Top of the SRAM)
                    LDR     r0, = Stack_Top                         ; get top of the stack
            MOV     sp, r0                                          ; store top of the stack in register0
                    ; Call Low level init
                    BL      LowLevelInit
                    NOP
    ; Cache Setup ------------------------------------------------------------------
                    IF      ICACHE_SETUP != 0
                    MRC     p15, 0, R0, c1, c0, 0   ; Enable Instruction Cache
                    ORR     R0, R0, #ICACHE_ENABLE
                    MCR     p15, 0, R0, c1, c0, 0
                    ENDIF
    ; Setup Stack for each mode ----------------------------------------------------
                    LDR     R0, =Stack_Top
    best regards
    Howard
