fiq doesn't work
hi
I wrote a code for LPC2378 about External INT, in IRQ mode works very well but in FIQ doesn't work and when I debug this the debugger stay on "FIQ_Handler B FIQ_Handler" in startup.s
this is for FIQ source code:
void FIQ_Handler( void ) __irq {
FIO0SET=0x200000; //set led1
EXTINT=1; //Acknowledge
VICVectAddr=0; //Acknowledge
j=0x0;
int main (){
. PINSEL4 = 0x00100000;
EXTMODE=1;
EXTPOLAR=0;
VICIntSelect=0x00004000;
VICIntEnable=0x00004000;
if write __fiq after (void) give an error that need "{" for the end of line.(I don't know why?)
but when I write this code, works very well:
__irq void int0_isr( void ) {
j=0x0;
int main (){
EXTMODE=1;
EXTPOLAR=0;
VICIntSelect=0x00000000;
VICVectAddr14=(unsigned long)int0_isr;
I increased FIQ mode stack size in startup.s but didn't have any effect
