uVision3 and Z-Wave
Hi!
I'm a student from Portugal developing a project using Z-Wave, specifically the Developers Kit (v5.00).
I have followed a tutorial provided by Zensys that instructed me how to setup a project for uVision2.
During the Build Target process on uVision3, I get a linker error:
*** FATAL ERROR L218: NOT AN OBJECT FILE
    FILE: C:\DevKit_5_00_Beta1\....\zw_slave_ZW030xs.lib
This seems to be an usual issue since I've already spotted the same problem at least twice in the Keil forums alone...
http://www.keil.com/forum/docs/thread12008.asp
http://www.keil.com/forum/docs/thread9736.asp
However, the threads end at the question phase...
Does anyone have an idea how to solve this?
Thanks,
Damiao
  • "I have followed a tutorial provided by Zensys that instructed me how to setup a project for uVision2."
    If you have followed their instructions, and they don't work, then you need to contact Zensys to find out why!
    It certainly looks like the zw_slave_ZW030xs.lib file is not a Keil-compatible library - so the first thing you need to do is confirm with Zensys that you have the correct library for use with Keil tools.
  • looks like this one has died the same death...
