Watchdog reset Philips 89v51RD2
Hello All!
I want to reset 89v51RD2 in less than 1 ms
after external Interrupt.
i wrote this code
void external(void) interrupt 0   // External INT0 ISR
EA = 0;       // interrupt disable
WDRE=1;
SWDT=1;
while(1);  // wait till reset
but it didn't worked.
Please help
According to Datasheet:
To protect the system against software deadlock, the user software must refresh the
WDT within a user-defined time period. If the software fails to do this periodical
refresh, an internal hardware reset will be initiated if enabled (WDRE = 1). The
software can be designed such that the WDT times out if the program does not work
properly.
The WDT in the device uses the system clock (XTAL1) as its time base. So strictly
speaking, it is a Watchdog counter rather than a Watchdog timer. The WDT register
will increment every 344,064 crystal clocks. The upper 8-bits of the time base register
(WDTD) are used as the reload register of the WDT.
The WDTS flag bit is set by WDT overflow and is not changed by WDT reset. User
software can clear WDTS by writing ‘1' to it.
Two SFRs (WDTC and WDTD)control Watchdog timer operation. During idle mode, WDT operation is temporarily
suspended, and resumes upon an interrupt exit from idle.
The time-out period of the WDT is calculated as follows:
Period = (255 - WDTD) 344064 1/fCLK (XTAL1)
where WDTD is the value loaded into the WDTD register and fosc is the oscillator
frequency
WDTC - Watchdog control register (address COH) bit allocation
Bit addressable; Reset value: 00H
Table:
Bit 7 6 5 4 3 2 1 0
Symbol - - - WDOUT WDRE WDTS WDT SWDT
Table: WDTC - Watchdog control register (address COH) bit description
Symbol > Description
WDOUT > Watchdog output enable. When this bit and WDRE are both set, a Watchdog reset will drive the reset pin active for 32 clocks.
WDRE > Watchdog timer reset enable. When set enables a Watchdog timerreset.
WDTS > Watchdog timer reset flag, when set indicates that a WDT reset occurred. Reset in software.
WDT > Watchdog timer refresh. Set by software to force a WDT reset.
SWDT > Start Watchdog timer, when set starts the WDT. When cleared,stops the WDT
Advance Thanks!
