Hi
I'm hoping someone miht be able to offer me some advice.
I am using RL-ARM (RTX RTOS) & RL-FSFLASH on an STM32.
I have a problem where I think our external watchdog is resetting the STM32 when I am performing some SD-Card I/O.
I'd like to measure the time, perhaps in the RTOS ticks, to see how long a routine takes.
Can anyone tell me is there an RTX os call that I can read ticks ?
Thanks in advance
Clive
* you can use the value of the hardware timer that RTX uses. * you should service the watchdog in the MCI_xxx.c file.
Found out
declare;
extern U16 os_time;
os_time ticks away at the rate specified in RTX_Conf_CM.c
#ifndef OS_TICK #define OS_TICK 1000 #endif
