Hi!
I am using 2-byte wide char strings in my application. Strings should be written and read from file (in flash FS). When using fwprintf(), i got in file only one byte per character, like converting UTF-8 to plain ASCII.
Here's my simple example:
int write_setup(DEVICE *bt_s) { FILE *fout; fout = fopen (INI_FILE,"w"); if (fout != NULL) { fwprintf (fout, L"NAME=%ls\n", bt_s->name); fclose (fout); return 0; } else return -1; }
When I call this function, the bt_s->name points to memory with following contents:
0x54 0x00 0x65 0x00 0x73 0x00 0x74 0x00 or in ascii: T<0>e<0>s<0>t<0>
when I check the file contents (with file hex editor), the ontents is plain ascii, one byte per character: 0x54 0x65 0x73 0x74, which is "Test"
Is this compiler related issue on using wide characters? What is proper use on file-wirting (and reading) wchar_t strings ?
Thanks!
Marko
Wide characters are converted to multibyte representation when written to a file. This requires selecting proper locale which can be done at link time or at runtime.
The easiest way is to select the UTF-8 multibyte encoding by adding the following into your code:
#pragma import(__use_utf8_ctype)
I made some further tests. I put some simple wchars:
// 0100;LATIN CAPITAL LETTER A WITH MACRON;Lu;0;L;0041 0304;;;;N;LATIN CAPITAL LETTER A MACRON;;;0101; fputwc(0x0100, fout); //03B1;GREEK SMALL LETTER ALPHA;Ll;0;L;;;;;N;;;0391;;0391 fputwc(0x03b1, fout);
But those two chars are not in file at all. The char is written to file as one-byte only when wchar is < 0x00ff.
And...the function
fwide (fout, 1);
returns 1.
I really don't know what I am doing wrong. I read infocenter.arm.com/.../DUI0349A_rvct_libraries_guide.pdf and some other manuals.
