I had code to configure the LPC 2378 as an SPI slave that appeared to be working, but now no longer does. Now, when I read the S0SPDR register, I always get 0xFFFF
PCONP |= 0x00000100; PINSEL0 &= ~0xC0000000; PINSEL1 &= ~0x0000003F; PINSEL0 |= 0xC0000000; PINSEL1 |= 0x0000003F; S0SPCR = 0x0004; //SLAVE mode; 16 bit transfers; MSB first; SPI Mode 0 while (1) { status = (S0SPSR & 0x0080); if (status) { data = S0SPDR;
"data" above always returns 0xFFFF. I looked at the SPI lines on a scope and they look correct. I read the SPTSR register and it shows no errors. I ran the same code on an LPC2478 development board with the same results
Thanks in advance, Bill F
wild guess: inappropriate clock divider value???
or maybe your peripheral expects the LSB first, rahter than the MSB...?
Thanks. I thought about that. My master (NI 8541) can be configured from clock speeds down to 1 kHz. I have sent data as low as 50 kHz (any lower and the SPIF flag is never set). The default for the SPI clock is CCLK/4. I went ahead and tried /2 and /1 by setting PCLKSEL0 with the same results. Is there another clock setting I need to set? The manual says the SPI Clock Counter Register is not relevant in SLAVE mode
Bill F
