init: (__use_two_region_memory)
I want to select the two region memory model. Therefore I have defined two execution regions in my scatter-loading file.
ARM_LIB_HEAP 0x20100000 EMPTY 0x100000â€'0x8000  ARM_LIB_STACK 0x20200000 EMPTY â€'0x8000
Is it ok to add this pragma (only) within my first c.code, where the main function exists..., or do I have to add this pragma within every c-file?
#pragma import(__use_two_region_memory)
void main(void)
Moreover I often see that there's another line in the scatter-loading file (working with atmel processors):
ScatterAssert(ImageLength(Relocate_region) <  0x6000)
e.g. (http://www.keil.com/forum/docs/thread13983.asp)
Could someone explain me the reason of this small line?
best regards
David
