UV2 preprocessor
uv2 -b "project name.uv2"
build the project.
Anyone knows of any switch which will invoke preprocessor option also.
I want to create the *.I files.
Regards,
John
  • C51 has pp option.. I want to put it in UV2...
    Regards,
    John
  • Anyone knows of any switch which will invoke preprocessor option also.
    I think you're looking for it in the wrong place. The option to keep preprocessor files is given to the compiler, not the IDE. I.e. you have to specify that option in the IDE project, not from the outside.
  • Thank you,
    I am sorry. You will not be able to understand why I need this option until I tell you.
    I want the preprocessed files for some processing by a certain application. The application takes input as the project (Uv2)file name and then invokes UV2 with -b option and builds it.
    I thought if there was a option to invoke the UV2 build with the preprocessing option enabled, then it would be helpful.
    I don't want to ask the user to set this option in the IDE.
    Regards,
    John
  • Yes, that should be obvious - so why didn't you tell us?!
    "The application takes input as the project (Uv2) file name and then invokes UV2 with -b option and builds it."
    Exactly - and it is the project (Uv2) file which specifies whether or not the preprocessor files will be generated.
    So, when you create the project (Uv2) file you have to create it with the option enabled.
    "I don't want to ask the user to set this option in the IDE."
    You don't have to - you just have to give them an appropriately-configured project (Uv2) file
  • Thanks Andy for the reply.
    Scenario:
    there is already a project file that some user is using.
    Now he wants to run my application on the project.
    But the project file doesn't have the preprocessor option enabled.
    How do I check for this/ or How do i enable this option on the command line.
    Would be really helpful if some one could help
    Regards,
    John
  • You can't, I'm afraid.
    It is part of the project file - the only way to change it is to change the project file
    "Now he wants to run my application on the project."
    If he wants to run your application on his project then, surely, it is up to him to ensure that his project is compatible with the requirements of your application - viz, that his project enables the preprocessor option?!
    Note that there is no reason for him not to do this - it will not affect his project in any way other than that the preprocessor files will be left in the listings folder.
    I always enable this as a matter of routine anyhow - it doesn't hurt, and you never know when it might come in useful!
    If he really won't change his project file, then note that the .uv2 file is just a simple text file - so your application could generate a temporary copy and enable the option in that...
  • Thanks Andy,
    But hope you would appreciate the fact that any end user always needs convenience and would never wish to do anything extra.. everything automatic.. thats what everyone likes..
    anyways thanks Andy once again .
    Regards,
    John
