SAM9263 STR register -> processor crashed
I need some help from you to boot from an external NOr flash device (together with the AT91SAM9263 controller from Atmel). I've tried to use the default setup file provided by Keil (SAM9263.s), but it doesn't work so far.
If I use the setup file from Keil - executing the code from the internal SRAM or the external SDRAM - everything is working.
I think that there's a timing problem in the original setup file if you try to boot from an external flash device. Therefore I want to configurate the SMC registers first and then enable the PLL. But at the moment, the processor crashed if I try to store the SMC registers - I don't know why....
There's the important part of the new setup file - the beginning and the end which are not visible, are both the same as in the original setup file from Keil.
; Reset Handler
                EXPORT  Reset_Handler
Reset_Handler
; Watchdog Timer Setup ---------------------------------------------------------
                IF      WDT_Val != 0
                LDR     R0, =WDT_BASE   ; Disable Watchdog
                LDR     R1, =WDT_Val
                STR     R1, [R0, #WDT_MR_OFS]
                ENDIF
; Setup Power Management Controller (PMC) --------------------------------------
                IF      :DEF:NO_PMC_INIT
                ELSE
                IF      PMC_SETUP != 0
                LDR     R0, =PMC_BASE
                ; System Clock Enable
                LDR     R1, =PMC_SCER_Val
                STR     R1, [R0, #PMC_SCER_OFS]
                ; Peripheral Clock Enable
                LDR     R1, =PMC_PCER_Val
                STR     R1, [R0, #PMC_PCER_OFS]
                ; Setup Main Oscillator
                IF      (CKGR_MOR_Val:AND:PMC_MOSCEN) != 0
                LDR     R1, =CKGR_MOR_Val
                STR     R1, [R0, #CKGR_MOR_OFS]
                ; Wait until Main Oscillator is stabilized
MOSCS_Loop      LDR     R2, [R0, #PMC_SR_OFS]
                ANDS    R2, R2, #PMC_MOSCS
                BEQ     MOSCS_Loop
                ENDIF
                ; Setup the PLL A
                IF      (CKGR_PLLAR_Val:AND:PMC_MUL) != 0
                LDR     R1, =CKGR_PLLAR_Val
                STR     R1, [R0, #CKGR_PLLAR_OFS]
                ; Wait until PLL A is stabilized
PLLA_Loop       LDR     R2, [R0, #PMC_SR_OFS]
                ANDS    R2, R2, #PMC_LOCKA
                BEQ     PLLA_Loop
                ENDIF
                                ENDIF
                                ENDIF
; Setup External Bus Interface (EBI) -------------------------------------------
                IF      EBI0_SETUP != 0
                LDR     R0, =MATRIX_BASE
                LDR     R1, =EBI0_CSA_Val
                STR     R1, [R0, #EBI0_CSA_OFS]
                ENDIF   ; of IF      EBI0_SETUP != 0
; Setup Static Memory Controller (SMC) -----------------------------------------
                ; Setup Static Memory Controller if enabled
                IF      SMC_SETUP != 0
                LDR     R0, =SMC_BASE
                ; Macro for setting the Static Memory Controller
                MACRO
$label          SMC_Cod $cs
$label          LDR     R1, =SMC_SETUP$cs._Val
                STR     R1, [R0, #SMC_SETUP$cs._OFS]
                LDR     R1, =SMC_PULSE$cs._Val
                STR     R1, [R0, #SMC_PULSE$cs._OFS]
                LDR     R1, =SMC_CYCLE$cs._Val
                STR     R1, [R0, #SMC_CYCLE$cs._OFS]
                LDR     R1, =SMC_MODE$cs._Val
                STR     R1, [R0, #SMC_MODE$cs._OFS]
                MEND
                IF      SMC_CS0_SETUP != 0  ; Setup SMC for CS0 if required
;SMC_0           SMC_Cod 0
;                               LDR     R1, =SMC_SETUP0_Val
                                LDR     R1, =0x02020202
;                STR     R1, [R0, #SMC_SETUP0_OFS]
                STR     R1, [R0]; {, #SMC_SETUP0_OFS}
; processor crashed at this point
;op{type}T{cond} Rt, [Rn] {, #offset}
;                LDR     R1, =SMC_PULSE0_Val
;                STR     R1, [R0, #SMC_PULSE0_OFS]
;                LDR     R1, =SMC_CYCLE0_Val
;                STR     R1, [R0, #SMC_CYCLE0_OFS]
;                LDR     R1, =SMC_MODE0_Val
;                STR     R1, [R0, #SMC_MODE0_OFS]
                ENDIF
                ENDIF   ; of IF      SMC_SETUP != 0
; Setup Stack for each mode ----------------------------------------------------
                LDR     R0, =Stack_Top
I'm not sure if there must be additional configurations before setting up the SMC registers...
best regards
Howard
  • I think that there's a timing problem in the original setup file if you try to boot from an external flash device.
    What do you base that thought on? I.e. what did you actually observe going wrong?
    Then why is does the code you show do it the other way round?
  • Hi,
    I want to boot from the nor flash. First of all, I have to configurate the SMC registers for the right access if the processor is running at 100 MHz.. At the startup the processor is running at 32kHz - therefore there's no problem to access the nor flash device....
    If I use the standard keil startup file, the processor is not able to reach the main function....
    I only configurate the PLL - but I don't set the PLL as active. That means, the processor is running at 32kHz, when I try to configurate the SMC registers - and after that step I will set the PLL and the processor clock.
    best regards
    Howard
