we have taken up the project automatic room light controller with visitor counter using at89s52..we have rigged up the circuit and have written the code too..but when it is dumped into the controller and executed the kit does not produce the expected result..we are getting random numbers like 17,99,etc and there is no decrementation happening at all..could you please go thro' the below code and point out what might be the mistake..the code is as follows:
LIGHT EQU P2.5 DIS1 EQU P2.7 DIS2 EQU P2.6 SEN1 EQU P1.0 SEN2 EQU P1.1 ORG 00H ;************************************************************************************ ;MAIN MOV R4,#00H MOV R5,#00H MOV P0,#0FFH ;make P0 output MOV P1,#0FFH ;make P1 input MOV P2,#0FFH ;make P2 output JNB SEN1,UPPC JNB SEN2,DOWNC AJMP DISPLAY UPPC: JB SEN2,DISPLAY INC R4 CJNE R4,#01H,UPP1 SETB LIGHT SETB DIS1 SETB DIS2 CALL CONV AJMP DISPLAY UPP1: CALL CONV AJMP DISPLAY DOWNC: JB SEN1,DISPLAY DEC R4 CJNE R4,#00H,DOWN1 CLR LIGHT AJMP DISPLAY DOWN1: CALL CONV AJMP DISPLAY ;******************************************************************************* ;CONVERSION CONV: MOV A,R4 MOV B,#10d DIV AB RR A RR A RR A RR A ADD A,B ;to get both the bcd digits in one register MOV R5,A RET ;********************************************************************************** ;DISPLAY DISPLAY: MOV P2, #80H MOV A, R5 ANL A, #0F0H CALL TRANS MOV P0,A CALL DELAY MOV P2,#40H MOV A,R5 ANL A,#0FH RR A RR A RR A RR A CALL TRANS MOV P0,A CALL DELAY JNB SEN1,UPPC JNB SEN2,DOWNC AJMP DISPLAY ;********************************************************************************* ;TO DECIDE THE NUMBER TO BE DISPLAYED TRANS: CJNE A,#00H,ONE MOV A,#0C0H RET ONE: CJNE A,#10H,TWO MOV A,#0F9H RET TWO: CJNE A,#20H,THREE MOV A,#0A4H RET THREE: CJNE A,#30H,FOUR MOV A,#0B0H RET FOUR: CJNE A,#40H,FIVE MOV A,#99H RET FIVE: CJNE A,#50H,SIX MOV A,#92H RET SIX: CJNE A,#60H,SEVEN MOV A,#82H RET SEVEN: CJNE A,#70H,EIGHT MOV A,#0F8H RET EIGHT: CJNE A,#80H,NINE MOV A,#80H RET NINE: MOV A,#98H RET ;************************************************************************************ ;DELAY OF 1ms DELAY: MOV R6,#2 MOV R7,#230 D1: DJNZ R7,D1 DJNZ R6,D1 RET END
thanks
the below code
what you show is not code but scribbles
code is commented
well this is the commented code..
LIGHT EQU P2.5 ;initialising variables DIS1 EQU P2.7 DIS2 EQU P2.6 SEN1 EQU P1.0 SEN2 EQU P1.1 ORG 00H ;************************************************************************************ ;MAIN MOV R4,#00H ;initialising count to zero MOV R5,#00H ;initialising counter to zero MOV P0,#0FFH ;make P0 output MOV P1,#0FFH ;make P1 input MOV P2,#0FFH ;make P2 output JNB SEN1,UPPC ;sensor value is low when obstructed JNB SEN2,DOWNC AJMP DISPLAY ;loop UPPC: JB SEN2,DISPLAY ;check for sen2 obstruction INC R4 CJNE R4,#01H,UPP1 SETB LIGHT ;light switched on SETB DIS1 ;activate display1 transistor SETB DIS2 ;activate display2 transistor CALL CONV ;hex to bcd conversion AJMP DISPLAY UPP1: CALL CONV AJMP DISPLAY DOWNC: JB SEN1,DISPLAY ;check for sen1 obstruction DEC R4 CJNE R4,#00H,DOWN1 CLR LIGHT ;switch off light when ppl leave AJMP DISPLAY DOWN1: CALL CONV AJMP DISPLAY ;******************************************************************************* ;CONVERSION CONV: MOV A,R4 MOV B,#10d DIV AB ;to get the first bcd digit RR A RR A RR A RR A ADD A,B ;get both digits in 1 register MOV R5,A ;get the bcd number in r5 RET ;****************************************************** ;DISPLAY DISPLAY: MOV P2, #80H ;selecting display1 MOV A, R5 ;move count to accumulator ANL A, #0F0H ;to get only first digit CALL TRANS ;to display the digit MOV P0,A CALL DELAY MOV P2,#40H ;select display2 MOV A,R5 ANL A,#0FH ;get the second digit of count RR A RR A RR A RR A CALL TRANS ;to display digit MOV P0,A CALL DELAY JNB SEN1,UPPC ;check for another entry JNB SEN2,DOWNC ;check for exit AJMP DISPLAY ;****************************************************** ;TO DECIDE THE NUMBER TO BE DISPLAYED TRANS: CJNE A,#00H,ONE MOV A,#0C0H RET ONE: CJNE A,#10H,TWO MOV A,#0F9H RET TWO: CJNE A,#20H,THREE MOV A,#0A4H RET THREE: CJNE A,#30H,FOUR MOV A,#0B0H RET FOUR: CJNE A,#40H,FIVE MOV A,#99H RET FIVE: CJNE A,#50H,SIX MOV A,#92H RET SIX: CJNE A,#60H,SEVEN MOV A,#82H RET SEVEN: CJNE A,#70H,EIGHT MOV A,#0F8H RET EIGHT: CJNE A,#80H,NINE MOV A,#80H RET NINE: MOV A,#98H RET ;****************************************************** ;DELAY OF 1ms DELAY: MOV R6,#2 MOV R7,#230 D1: DJNZ R7,D1 DJNZ R6,D1 RET END
will be glad if you can make sense of the comments and can help:) thanks..
Sorry, but I don't have the time to run through the code thoroughly.
This stood out though:
You load all ports with the same 0FFh, but say P0 and P2 are output and P1 is an input. You may want to read the manual to get better understanding of '51 ports.
oh thanks for pointing it out..i gotta look it up once..and if you could spare some time,even if not immediately, i would be happy to take any other suggestions too..thanks a lot for this reply though..will check that out:)
Unlike many other processors, the standard 8051 port does not have a configurable "direction" ("in" or "out")
See: www.8052.com/.../120176
totally misleading label
the CJNE jumps if not zero, there is no determination that the values is one.
also you have no facility for "switch debounce". YES, even a light sensor may need 'debounce', e.g. if low what about 'open legs', e.g. if higher what about swinging arms? also, I have no doubt that you may get two or more pulses if a fur is worn. A quick look at yor code seens to show that if a person stand still in the lightpath the counter will count and count snd count ....
@andy neil ok then do you think we can write the code without specifying the ports as input or output??i mean we remove the following lines..
mov p1,#0ffh mov p2,#0ffh mov p3,#0ffh
@erik well the concept of cjne a,#00h,one is to determine what number available at the counter..if it is not 0 then we check for one and so on upto 9..and the display in each segment does not exceed these 10 digits..so i guess that justifies my display part..coming to the second part of your reply..we have recognised these faults in the circuit at the beginning itself but right now we r jus planning a prototype for our academic curriculum..the points you stated will obviously be the disadvantages of our project:):)we only want to show that when an object obstructs the sensors the counters r incremented or decremented depending on the entry and exit.but right now the increment is happening in huge leaps like it goes from 71 to 82 or decrements from 61 to 54 etc...hope this makes it a bit clear as to what my problem is..
If you read the linked FAQ, it answers that!
FAQ: www.8052.com/.../120176
"i mean we remove the following lines"
If you just remove them without understanding why, then you will almost certainly break something somewhere else in your code!
You need to understand the working of the 8051 ports; See the above FAQ for a start;
Also: www.8052.com/.../120112
And: http://www.8052.com/tutorial
And probably also: http://www.keil.com/books/8051books.asp
If you jump to the label "TWO" if you have deduced that the number is two, then the label is quote ok.
But if you jump to the label "TWO" to try to figure out if it is two or something higher, then it would be better with a label "TEST_IF_TWO" - right now, it looks more like a promise: "If I jump here, I promise that the number must have the value two."
I stated :"A quick look at yor code seens to show that if a person stand still in the lightpath the counter will count and count snd count" your problem right now the increment is happening in huge leaps like it goes from 71 to 82 or decrements from 61 to 54 etc...hope this makes it a bit clear as to what my problem is.. is the time "a person stand still in the lightpath"
but right now we r jus planning a prototype for our academic curriculum so you "jus(t) r (resist) planning", that is VERY obvious. There is ZERO thought behind your code.
