Max. Ethernet Frame Size
I have board MCB2300 (with LPC 2378 microprocessor).
I read in LPC23xx User manual that
MAXIMUM FRAME LENGTH (MAXF)sets to the value 0x0600, which represents a maximum receive frame of
1536 octets.
This way,
max. outgoing TCP data size should be less than (1536 - ETH_HEADER_SIZE - IP_HEADER_SIZE - TCP_HEADER_SIZE).
The result is 1536-14-20-20 = 1482 bytes.
Is it possible to transmit more than 1536 bytes via ethernet once only?
