I am trying to print out a file from flash system on ITM dedug channel on STM32, but it only sends the first part, i can't figure out why...
The flash system reads the whole file (20 chars) into a buffer and i print it out with fprintf...
I have retarget the _sys_write to ITM, but it only sends the first 10 chars.
It seems like the fprintf function calls the _sys_write with a buffer of 10char's and then it seems like it forget to call the function again with the for the rest of the buffer, because when i get out of fprint function the last part of file is putted into the ram area where the first part was when printet...
It is proberly small error i have made :(
Here is my code:
#define db_print(...) fprintf(stderr, __VA_ARGS__) char line[80]; /* Read a file from default drive. */ f = fopen ("M:\\xxx.TXT","r"); if (f == NULL) { db_print ("\r\nFile not found!\n"); } else { fgets (line,30, f); db_print ("\r\ndata: %s",line); // process file content fclose (f);
And now the retarget function
int _sys_write (FILEHANDLE fh, const U8 *buf, U32 len, int mode) { #ifdef STDIO if (fh == STDOUT) { /* Standard Output device. */ // for ( ; len; len--) { // sendchar (*buf++); // } return (0); } if (fh == STDERR) { for ( ; len; len--) { if (DEMCR & TRCENA) { while (ITM_Port32(0) == 0); ITM_Port8(0) = *buf++; } } return (0); } #endif if (fh > 0x8000) { return (-1); } return (__write (fh, buf, len)); }
Is there any other function i need to re-target??
Kasper
