Keil RTX Task, FIQ & SW IRQ Interraction
Besides an RTX task polling, is there any glue that interconnects an FIQ with an RTX task?
Details below and thank you for your help,
Lonnie
Details
I have a peripheral driver (ARM Cortex) that is asynchronous and triggers an FIQ when it receives data. The FIQ analyzes the data (checks to see if it had received the correct closing sequence). Now, somehow I need to inform an RTX task that the complete set of data has been received.
Since FIQ cannot call RTX functions, how can I inform the task that there is data ready?
I can only think of polling.
Unless, there is some way to mate an RTX software interrupt to the peripheral?
  • Is this what you mean?
    // DO NOT CALL THIS FUNCTION FROM PROGRAM CONTEXT - ONLY FROM FIRMWARE INTERRUPT CONTEXT !!!
    void report_event_to_application(logical_id a_logical_id, int32u a_signal)
            task_info_t *lp_task_info = g_task_info ;
            int32u           l_index = NUMBER_OF_APPLICATION_USER_TASKS - 1 ;
            do
                    if (lp_task_info->logical_id == a_logical_id)
                            isr_evt_set(a_signal, lp_task_info->id) ;  // must not be invoked from program content - only interrupt mode
                            break ;
                    ++lp_task_info ;
            while ( (l_index--) > 0 ) ;
  • Thank you for your response!
    I thought isr_evt_set() could not called from an FIQ interrupt.
    I tried it - with no success.
    I single stepped through the interrupt and interrupt calls the event.
    However, the RTX task that is waiting on the event never sees the event being signaled.
  • I guess you better ask Keil support or consult the RTX manual for your target. I don't know your chip (yet).
  • ARM Cortex-M3 (ST STM32)
    According to the > RL-RTX > Theory of Operation > Interrupt Functions
    -You cannot call the isr_ library functions from the FIQ interrupt function.
    www.keil.com/.../rlarm_ar_inter_funct.htm
    With this in mind, I could have a task pole for a bit
    /* global bit that is poled for completion */
    volatile BIT bRcvdMsg = __FALSE;
    void USART1_IRQHandler(void)
        /* do some message checking here and if
        ** ok - then inform the task by setting a bit */
        bRcvdMsg = __TRUE;
    __task void taskUSARTPollingTask( void )
        for(;;)
            /* Just wait for a complete message to be received to inform
            **              the RS232 Handler Task */
            if(bRcvdMsg == __TRUE)
                /* Inform the RS232 Handler Task */
                isr_evt_set ( EM_DSP_USART_RCVD , g_taskCLI);
            os_dly_wait (20);
    --- OR ---
    May be use SVC Functions or SWI Functions to map to the interrupt handler? Then use that to trigger the task. I haven't really seen this done in a task where they were using the RTX (at least not for the IC I am using). Any ideas?
  • Sorry - In the previous message, please replace
    isr_evt_set() with
    os_evt_set()
  • if(bRcvdMsg == __TRUE)
    here you are trying to use the isr_evt_set function from user mode. that won't work.
    why do you need a FIQ? can't you put up with a high priority IRQ?
  • Oops, you corrected yourself already. But my second comment stands: why not IRQ?
  • What about:
    1 - FIQ does it's processing and detects 'completion'
    2 - On completion, FIQ triggers a software generated IRQ
    3 - IRQ does nothing except call isr_evt_set
    I'm not familiar with your processor, but I have done this very same sequence successfully on an STR9.
  • There is no FIQ in Cortex-M, so there is no such problem. The core peripheral NVIC is used to generate exceptions. It is safe to use isr_xxx functions from the exception handlers.
  • Thank you for all the responses!!
    (Sorry for the long wait - I have been on vacation)
    Good news, the problem is fixed.
    With all the comments, I focused on the code again and realized the functionality I was performing inside the interrupt was causing the problem. Not the isr function call from the IRQ.
    Thanks again for all your help!!
