Linker code packing breaks breakpoints
uVision 4, C8051F360, C2 debugging
I've notice that I can no longer set breakpoints anywhere in my program after enabling, then disabling, linker code packing. ('anywhere' litterally means no breakpoints anywhere in the entire program)
They work when I enable linker code packing, and now do not work when I disable linker code packing.
It's like something in the IDE got switched when I enabled LCP, but now won't switch back when I disable LCP.
I noticed that I can exit debug mode, set a breakpoint (with an LCP compiled program), then go back into debug mode and I get an error in the command window:
BS \MAIN\93
____^
*** error 35: undefined line number
Using the Breakkill command:
Breakkill
*** error 34: undefined identifier
Updated the silabs debug driver and still have the same problem.
Any thoughts?
