S3C2440 Interrupt problem
Hi all,
I am developing program for UART0 with Interrupt.
void uart_init(void);
void uart_transmit(void);
void uart_interrupt_init(void);
void dely(U32 tt);
static void __irq Uart0RxInt(void);
char data,flag=0;
{ INTSUBMSK = 0xFFFFFFFF; SUBSRCPND = 0x1; SRCPND |= 0x10000000; INTPND = 0x10000000;
data = rURXH0;  flag = 1;
GPBDAT=0xFFFFFFFF; dely(12); GPBDAT=0x00000000; dely(12);*/
void dely(U32 tt)
{ U32 i; for(;tt>0;tt--) { for(i=0;i<10000;i++){} }
int Main(int argc, char **argv)
{ int i; U8 key; U32 mpll_val=0; int data; unsigned int k,l;
mpll_val = (92<<12)|(1<<4)|(1);
MMU_DisableICache(); MMU_DisableDCache();
GPBCON = 0x155555; GPHCON |= 0xAA; uart_init(); uart_interrupt_init(); while(1) { while(flag!=1); uart_transmit(); flag=0; } INTSUBMSK = 0xFFFFFFFF; INTMSK = 0xFFFFFFFF;
{ ULCON0 |= 0x00000003; UCON0 |= 0x00000005; UMCON0 = 0x00; UFCON0 = 0x00; UBRDIV0=329; // 9600 //UBRDIV0=27; // 115200
{ pISR_UART0 = (unsigned int)Uart0RxInt; SUBSRCPND = 0x1; SRCPND = (1<<28); INTPND = (1<<28); INTSUBMSK = 0xFFFFFFFE; INTMSK = 0xEFFFFFFF;
{ while((UTRSTAT0&0x00000002)==0); UTXH0=data;
when i download the code & run, it gives Dummy_isr error.
please help me
  • What is Dummy_isr error? Your code does not contain any symbol with that name.
    By the way - the lack of formatting indicates that you have already done some bad copy/paste of that code making it unreadable.
    You shouldn't have taken the broken code from your previous thread. You should have copied the code from your source code editor. And you shouldn't have started a new thread - just added one more post with corrected source code formatting.
