i try to do the examples from the "Insider's Guide to the PHILPS ARM73" by the example 3 the compiler reports: main.c(31): error: #130: expected a "{" main.c(41): error: #130: expected a "{"
The code is very simple: ==================================================== #include <LPC21xx.H>
void thumb_function(void);
int main(void) __arm { IODIR1 = 0x00FF0000; ... }
void thumb_function(void) __thumb { ... } ==================================================== It seems the compiler not recognizes the "_arm"-Macro. I use the µVision V4.00 with the Keil-Compiler.
could you tell me how cann i set the Compiler in the µVision ? Thanke you for your help
