LCD interfacing
Hi all,
I am interfacing 16x2 character LCD to P89LV51 and using 8bit interface mode, I am initializing the LCD by this sequence
function set - 0x38
display control- 0x0f
entry mode set- 0x06
cursur shift- 0x14
clear display - 0x01
and finally displaying the string
but after initializing, display is blank, instead of busy check, i used delay then, still the display is void. I used the LCD initialization as given HD44780U datasheet. Still No display. But Same LCD is working actually with some other code. Can somebody tell me the exact problem.
  • your device has a series of strict timing requirements related to power supply and bus usage. have you verified that you are compliant?
  • But Same LCD is working actually with some other code
    look at her code and seee the direfences.
  • Hi my frend,
    Please post your project (simplified if you want) in a zipped or rared form to rapidshare, including also the asm with the working hardcoded delays.
    Sorry but I dont' have a program with busy checking but Im'm working with code also in very diffucult assembly, hope I can help you.
    However, my quick ideas are here:
    1. Also for check only the busy flag (bit 7) you must read back the whole byte (both nybbles) !!
    2. Do you make the proper port (data pins) direction alterings ? (onley the busy checking needs ouput(and input ?????) 0...3 as inputs)
    zuisti
    (chief programmer)
