PC-LINT ERROR 129 In RTX Header File - RTL.H
We are attempting to run PC-Lint (version 8.00u) on our
Keil project which uses the RL-ARM Real-Time Library Version V3.24.
We have set up PC-Lint to use the latest example PC-Lint Configuration File for the CARM Compiler as downloaded from Keil's web-site. File name:CO-RV.LNT
Lint reports the following error in RTX's rtl.h header file.
C:\Keil\ARM\RV31\INC\rtl.h(351,7): Error 129: declaration expected, identifier 'FINFO' ignored
FINFO is a defined structure in rtl.h as follows
typedef struct {
   S8  name[256];
   U32 size;
   U16 fileID;
   U8  attrib;
   struct {
      U8  hr;
      U8  min;
      U8  sec;
      U8  day;
      U8  mon;
      U16 year;
   } time;
} FINFO;
Obviously we are loathe to start changing any of the supplied RTX OS header files.
To simplify the problem we created a new empty project with just the include directive:
#include <rtl.h>
Error 129 in rtl.h is still reported by PC-Lint.
Does anyone know how to resolve this Lint error?
Thank you
John
  • I've resolved the problem.
    Keil's CO-RV.LNT Lint configuration file does not cover the use of __swi functions.
    The Lint error suggested the structure FINFO was the issue but PC-Lint reports no errors when the __swi definitions in rtl.h are commented out.
    In order to get Lint to accept __swi declarations you
    need to add an additional rule to the lint configuration file. I call CO-RV.LNT from within another .LNT file and put the additional rule in my own .LNT file.
    So, my file, called STD_ARM.LNT contains:
    //  Keil RealView compiler
    //  Standard lint options
    CO-RV.LNT
    +d__swi=_to_brackets
    +rw(_to_brackets)
    The _to_brackets option removes the associated error. PC-Lint returns no errors.
    John
  • Just now I got the same error when I started linting my new Cortex-M3 project first time. I fixed it like above mentioned. - John, many thanks for your posting!
