Hi All: I have a problem when I use “isr_evt_set†in my UART interrupt routine: It ca not reach to “ os_evt_wait_or(0x0001,0xffff);â€
But if I just change “isr_evt_set†to “os_evt_setâ€, my code works fine. Anybody knows what’s wrong? I am using MCB2300 board. Part of code here:
void UART3Handler (void) __irq { isr_evt_set(0x0001,UART3_TASK); /*use "os_evt_set" works*/ VICVectAddr = 0; /* Acknowledge Interrupt */ } void task_UART3_received (void) __task { BYTE IIRValue, LSRValue; BYTE Dummy = Dummy; for(;;) { can not get here if I use "isr_evt_set": os_evt_wait_or(0x0001,0xffff); ...... }
Thanks Jack
Sorry some chars can not be read, post my question again: Hi All: I have a problem when I use "isr_evt_set" in my UART interrupt routine: It can not reach to "os_evt_wait_or(0x0001,0xffff);"
But if I just change "isr_evt_set"to "os_evt_set", my code works fine. Anybody knows what's wrong? I am using MCB2300 board. see my code above
Jack
Hi Jack,
is your system startup deterministic? Do you have UART task3 actually created when the first interrupt occurs?
By using "os_evt_set" you may compensate a existing error through the introduction of an second error.
-Frank
Thank you Frank! I did not change anything in LPC2300.s. what system startup deterministics mean? I am sure all tasks are created before the first interrupt occurs.
Zhen
Deterministic - order of creation always the same.
Great care should be used when the first threads starts running while you are busy creating more threads - or interrupts starts to tick.
Hi Per Westermark, I will review my code first tomorrow. Thanks again Jack
