I downloaded the newer version of the demo RealView Compiler (3.23) and suddenly whenever I compile a program for my LPC2103 it adds 16 KB of read only data. No matter how small and simple the program is.
It looks like they increased the debug limit from 16KB to 32KB also. That makes me think they are aware that programs are now going to be 16KB larger so they needed to expand the limits of the demo. But does anyone know why it would be using the space.
It looks like a total waste. In the map file it says that it is all (incl. padding) RO-data. Which makes me think its just empty padding. Is there some option I'm missing? Or some checkbox to check to turn off this 16KB of empty space, or some reason for it to be appearing?
I'm at a complete loss.
Andy; I really don't know why Keil did this but I can guess. They are attempting to limit the eval from running small programs that can execute in 16K. The user would not require the full purchase version for real developement. Keil did a similiar thing with the PK51 many years ago when the eval could run a 4K program. They offset the startup by 4K so you could not use the many 4K devices in real production. So, I'm guessing they attempting to offset the code by 16K. Remember, I'm just guessing at this. Bradford
I am evaluating the Cortex M3 Luminary LM3S811.
At first I thought the Keil Compiler produces really awful code! Or maybe I am doing something wrong? But then again, even the provided simple 'blinky' sample was showing the same auful code.
I do not give up too quickly. Much of yesterday I tried to get around the 16 K limit after noticing a 16 K 'ro' section apperently doing nothing.
What a pain in the neck. I can live with an honest 16 K limit for evaluation purposes, although 32 K are nicer. How about a compromise of 24 K. Honest.
Herr Klaus; I suggest that you forward your post to Keil sales people or Keil Tech support. The Ops on this forum are customers like you and we have no input to the Keil eval specifics. Bradford
See: http://www.keil.com/forum/docs/thread13554.asp#msg67600
