Hi, I am having a problem in enabling the interrupts for UART1 in LPC2368. Program is getting stucked at the point where I am writing value to the UART1 Interrupt Enable Register.
U1IER = 0x07; /*Enable RDA, THRE and RLS Interrupts*/
I tried to print value of U1IER, but nothing gets printed. U1IER and U1DLM shares same address i.e. 0xE0010004. Hence I tried to read/write this address directly, still got nothing. When I initialized UART1 with
void UART1_Init(void) { /* RxD1 and TxD1 */ printf("In UART1 initialization\n"); PINSEL0 |= 0x40000000; /* Enable TxD1 P0.15 */ PINSEL1 |= 0x00000001; /* Enable RxD1 P0.16 */ /* U1LCR: UART1 Line Control Register 0x83: enable Divisor Latch access, set 8-bit word length, 1 stop bit, no parity, disable break transmission */ U1LCR = 0x83; /* U1DLM: UART1 Divisor Latch (MSB) */ //baudrate = 9600 U1DLM = DIVISOR1/256; printf("U1DLM = %X \n",U1DLM); //This is just for checking value of U1DLM. //Here nothing gets printed but program executes after this /* U1DLL: UART1 Divisor Latch (LSB) */ U1DLL = DIVISOR1%256; /* U1LCR: UART1 Line Control Register 0x03: same as above, but disable Divisor Latch access */ U1LCR = 0x03 ; /* U1FCR: UART1 FIFO Control Register 0x07: Clear Tx FIFO and enable Rx and Tx FIFOs */ U1FCR = 0x07 ; //0x07 : Rx Trigger level 1 byte, FIFO Enable, Tx FIFO Reset, Rx FIFO Reset U1IER = IER_RBR | IER_THRE | IER_RLS; /*Enable UART1 interrupt */ //here program gets stucked. }
I tried last statement at various places like inside initialization as well as after initialization in main function. What could be the problem?
Thanks.
