I'm trying to change the input report to 100 but it doen't work. I read almost all the threads of Tsuneo, but i can not get it to work. When I use the "SimpleHIDwrite" and try to get the reports i get "Get Report Error: Data Error (Cyclic redundancy check) (17)".
This only happens when i tried to make the input_report > 64 Bytes, otherwise works perfect other thing is that i read that if the packet that you send is smaller is automatically reduced, but not to me :(. From USBcfg.h i have the nexts defines
#define USB_MAX_PACKET0 64 #define InReport_length 100
Here i will put my report descriptor:
const BYTE HID_ReportDescriptor[] = { HID_UsagePageVendor( 0x00 ), HID_Usage( 0x01 ), HID_Collection( HID_Application ), HID_LogicalMin( 0 ), HID_LogicalMaxS( 0xFF ), HID_ReportSize( 8 ), // bits HID_ReportCount( InReport_length ), // bytes HID_Usage( 0x01 ), HID_Input( HID_Data | HID_Variable | HID_Absolute ), HID_ReportCount( 4 ), // bytes HID_Usage( 0x01 ), HID_Output( HID_Data | HID_Variable | HID_Absolute ), HID_EndCollection, }; const WORD HID_ReportDescSize = sizeof(HID_ReportDescriptor);
This part is in USBconfigdescriptor[]
const BYTE USB_ConfigDescriptor[] = { ..... ..... USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_IN(1), /* bEndpointAddress */ USB_ENDPOINT_TYPE_INTERRUPT, /* bmAttributes */ WBVAL(0x0040), /* wMaxPacketSize */ 0x02, /* 2ms */ /* bInterval */ /* Terminator */ 0 /* bLength */ };
I think that the problem may be is in hiduser.c but i could't check it because i didn't find code for this
BOOL HID_GetReport (void) { int i; /* ReportID = SetupPacket.wValue.WB.L; */ switch (SetupPacket.wValue.WB.H) { case HID_REPORT_INPUT: GetInReport(); for(i=0;i< InReport_length ;i++) EP0Buf[i] = InReport[i]; /*Copy all the report to send*/ break; case HID_REPORT_OUTPUT: return (FALSE); /* Not Supported */ case HID_REPORT_FEATURE: /* EP0Buf[] = ...; */ /* break; */ return (FALSE); /* Not Supported */ } return (TRUE); }
where EP0Buf[] is define in USBcore.h
extern BYTE EP0Buf[USB_MAX_PACKET0];
Of course i realized that EP0Buf was smaller so i tried doing
extern BYTE EP0Buf[InReport_length];
but was the same Endpoint 1 is
void USB_EndPoint1 (DWORD event) { InEP_empty = TRUE; }
If you need more info to deduce my problem just tell me.. Thanks
Sorry, for my late response, It takes for a while to find my free time to check your modification on a working board.
Your modification for Get_Report( INPUT ) request handling is fine. The problem should be in other place.
In the report descriptor, you increased the byte size of input and output report. Did you modify - interrupt IN endpoint handler for input report - Get_Report( OUTPUT ) request handler for output report
Maybe, the bug lies in the interrupt IN endpoint handler.
Tsuneo
Auu, my bad, In above post, Get_Report( OUTPUT ) <-- Set_Report( OUTPUT )
The SetReport (output ) is this.
BOOL HID_SetReport (void) { int i; /* ReportID = SetupPacket.wValue.WB.L; */ switch (SetupPacket.wValue.WB.H) { case HID_REPORT_INPUT: return (FALSE); /* Not Supported */ case HID_REPORT_OUTPUT: for (i = 0; i < USB_MAX_PACKET0; i++) { /* whole packet is copied */ OutReport[i] = EP0Buf[i]; } SetOutReport(); break; case HID_REPORT_FEATURE: return (FALSE); /* Not Supported */ } return (TRUE); }
The problem is in the Input report, you can noticed that i'm only replying when i have data to do it. I solve my problem in a rustic way, i split my self the packet, but i would like to know what is the problem here.
Tsuneo, you don't have to apologize because of the time it takes you to reply, you always reply and that is the most important. Thank you for your time and dedication :D
"The problem is in the Input report, you can noticed that i'm only replying when i have data to do it."
Ummm... I din't notice it. Your above code for Get_Report( INPUT ) always returns a valid input report. But if you return STALL to Get_Report( INPUT ), it'll cause error and the host will reset the device by bus reset. Get_Report( INPUT ) has to be always answered, regardless of the reason of the device side.
Unfortunately, the HID spec doesn't describe this restriction clearly. It notes that the support of Get_Report is mandatory: This means the device should always return a valid reply to Get_Report request. STALL to Get_Report occurs just when any one of the SETUP parameters is invalid (wValue, wIndex and wLength).
For above strategy, use the interrupt IN endpoint, instead.
Also, Get_Report and Set_Report doesn't fit to repeated access. For repeated access, use interrupt IN/OUT endpoint. "I solve my problem in a rustic way, i split my self the packet, but i would like to know what is the problem here."
I copied your modification to this example, and it works fine. I suppressed the interrupt IN EP handler temporarily.
LPC2368 / LPC2378 USB HID (Human Interface Device) Example http://www.keil.com/download/docs/335.asp
As I can't find any error on your modification, it was required to check it on a working board, to ensure my answer. When I see some error, I just point it out without running it. :-)
Doesn't the problem lie in the input report from the interrupt IN endpoint ?
