I m using AT89C51 for digital clock, with external clock.
i want to set the port0-1-2 for parallel data, and port3 for serial data
the problem is to define the port as input or Output
Master Clock ------------------ port0 for input port1 for output port2 for output port3 for output (to send serial data)
Slave Clock ------------------ port0 for output port1 for output port2 for output port3 for input (to receive data)
please tell me how can i set the ports for input and/or as outpur
What is port0, port1, port2, port3? Individual pins or full 8-bit ports?
With most 8051 chips, you don't have to change a setting to use a pin as input or output. It has a weak pull-up, so when you set the pin as high from the inside, any external equipment can use it as an input. If you set the pin as low from your program, it will be able to sink current.
Just note that the reset state is the weak pull-up state, and it really is weak and not intended to supply power to a LED or similar.
Have you spent time reading up on the 8051 in general, and your specific chip?
See: www.8052.com/.../120176
And: www.8052.com/.../120112
Thanks to support me, ports0-3 are full 8-bit ports.
I m sending my source code please inform me any types of errors
I shell be very thankful to you.
org 00h ;Set up Timer 1 MOV IE, #0 ; Disable all interrupt MOV TMOD, #020h ; Timer 1: Mode 2 (8-bit reload) MOV TH1, #230d ; Reload value for 1201, SMOD = 0 MOV TL1, #230d ; Make first time-out correct ANL PCON, #07fh ; To make SMOD =0 ;Set up serial ports MOV SCON, #50h ; Timer 1 : Mode 1 (vari baud) and set receive enable SETB TR1 ; Start timer 1 mov r1, #6d mov r2, #91d mov r3, #63d mov r4, #63d MainLoop: setb p0.7 mov r7, #90d SubLoop: mov r6, #90d InnerSpot: jmp DisplayData InnerSpot1: djnz r6, InnerSpot djnz r7, SubLoop clr p0.7 mov r7, #90d SubLoop1: mov r6, #90d InnerSpot12: jmp DisplayData InnerSpot11: djnz r6, InnerSpot12 djnz r7, SubLoop1 jmp MainLoop DisplayData: mov C, p2.7 orl C, p0.7 mov b, r1 mov p2, b JNC Skip1 mov b, #254d mov p1, b Skip1: mov b, #255d mov p1, b mov b, r2 mov p2, b JNC Skip2 mov b, #253d mov p1, b Skip2: mov b, #255d mov p1, b mov b, r3 mov p2, b JNC Skip3 mov b, #251d mov p1, b Skip3: mov b, #255d mov p1, b mov b, r4 mov p2, b JNC Skip4 mov b, #247d mov p1, b Skip4: mov b, #255d mov p1, b jnb RI, CheckReturnPoint clr RI mov a, sbuf cjne a, #246d, CountCountinus mov r0, #0d CheckReturnPoint: mov c, p0.7 jc InnerSpot1 jnc InnerSpot11 CountCountinus: inc r0 DigOne: cjne r0, #1d, DigTwo mov r1, a Jmp DisplayData DigTwo: cjne r0, #2d, DigThree mov r2, a Jmp DisplayData DigThree: cjne r0, #3d, DigFour mov r3, a Jmp DisplayData DigFour: cjne r0, #4d, CheckReturnPoint mov r0, #0d mov r4, a Jmp DisplayData End
thanks
very important help
i m really thankful to you
from tyhe above ;Set up serial ports
