Doubt on FAT file system
Hi to all, i am referring www.siwawi.arubi.uni-kl.de/.../
i made some changes on the code and i got some results :).
my code from main.c is:
    FATFS *fs;/* Pointer to file system object */
    DWORD fre_clust, fre_sect, tot_sect;
    DRESULT Disk;
    FRESULT res1;
    IoInit(); //Timer, UART and LED initialize
    xputs("\nFatFs module test monitor for LPC2388");
    w1 = f_mount(0,fs); // mounting logical drive 0
    xprintf("\r\nmount status %d",w1);
//    res = disk_initialize(0); // physical drive 0. But i dont know why
//      xprintf("\r\n Return value of diak_initilize() is %d",res);
     Disk = disk_status(0); // status if physical drive 0
     xprintf("\r\n Return value of diak_status() is %x",Disk);
    // Get drive information and free clusters
    res1 = f_getfree("/Test.txt", &fre_clust, &fs);
    if (res1)
        put_rc(res1);
    xprintf("\r\n Retuen value of getfree() is %d",res1);
//      xprintf("\r\n Free Clusters %ld",fre_clust);
    // Get total sectors and free sectors
    tot_sect = (fs->max_clust - 2) * fs->csize;
    fre_sect = fre_clust * fs->csize;
    // Print free space in unit of KB (assuming 512B/sector)
    xprintf("%\r\nlu KB total drive space.\n"
           "%lu KB available.\n",
           fre_sect / 2, tot_sect / 2);
    // Open source file
    res1 = f_open(&file1, "Test.txt", FA_OPEN_EXISTING | FA_READ);
    if (res1)
                put_rc(res1);
        xprintf("\r\n status Opening Test1 file %d",res1);
    // Create destination file
    res1 = f_open(&file2, "b.txt", FA_CREATE_ALWAYS | FA_WRITE);
    if (res1)
                put_rc(res1);
        xprintf("\r\n status of opening b file %d",res1);
    // Copy source to destination
    for (;;)
        res1 = f_read(&file1, Buff, sizeof(Buff), &br);
        if (res1 || br == 0)
                        put_rc(res1);
                        xprintf("\r\n Reading status %d",res1);
                        break;   // error or eof
                xprintf("\r\n Read sta %d",w1);
        res1 = f_write(&file2, Buff, br, &bw);
        if (res1 || bw < br)
                        put_rc(res1);
                        xprintf("\r\n write status %d",res1);
                        break;   // error or disk full
        xprintf("\r\n Write Sta %d",w1);
   // Close all files
    f_close(&file1);
    f_close(&file2);
    // Unregister a work area before discard it
    f_mount(0, NULL);
i give the result here.
mount status 0
Return value of diak_status() is MCI_INIT ok
no timeout on CMD8 -> SD-Card>=Version 2.0
ACMD41 success -> SD-Card SC or HC
SDSC detected
MCI_Send_CSD result: 002f0032 5f5983bd edb7ff9f 964000a8
setting 4bit width success
rc=11 FR_NO_FILESYSTEM
Retuen value of getfree() is 11MCI_INIT ok
SDSC detected
status Opening Test1 file 11MCI_INIT ok
SDSC detected
i have formatted my SD card at FAT32 fs...
but here the same statement repeated three times. And even some data has been suppressed.
I dont know whats the MCI_Send_CSD result?
What those values specifies?
Then i tried to fwrite a file and copy that file to another file. but i always failed. Y?
The way i am going on is correct or not?
From Andy and per's lot of reply helped me to come to this level. But still i need more....
