Hi I aam sending code for timer problem is that code goes inside handler for a long time (till then LED is off) please suggest the right code
void main(void) { #ifdef DEBUG debug(); #endif SCU_APBPeriphClockConfig(__TIM01, ENABLE); /* Enable the clock for TIM0 and TIM1 */ TIM_DeInit(TIM0); /* TIM0 Deinitialization */ SCU_APBPeriphClockConfig(__TIM23, ENABLE); /* Enable the clock for TIM2 and TIM3 */ TIM_DeInit(TIM2); /* TIM2 Deinitialization */ SCU_APBPeriphClockConfig(__GPIO9, ENABLE); /* GPIO Structure Initialization */ GPIO_StructInit(&GPIO_InitStructure); SCU_AHBPeriphClockConfig(__VIC,ENABLE); SCU_AHBPeriphReset(__VIC,DISABLE); VIC_DeInit(); VIC_Config(TIM2_ITLine, VIC_IRQ, 0); VIC_ITCmd(TIM2_ITLine, ENABLE); /*GPIO9 for LED*/ GPIO_DeInit(GPIO9); GPIO_InitStructure.GPIO_Direction = GPIO_PinOutput; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1 ; GPIO_InitStructure.GPIO_Type = GPIO_Type_PushPull ; GPIO_Init (GPIO9, &GPIO_InitStructure); GPIO_WriteBit(GPIO9, GPIO_Pin_0, Bit_RESET); GPIO_WriteBit(GPIO9, GPIO_Pin_1, Bit_RESET); /*TIM2 Structure Initialization*/ TIM_StructInit(&TIM_InitStructure); TIM_InitStructure.TIM_Mode = TIM_OCM_CHANNEL_1; TIM_InitStructure.TIM_OC1_Modes = TIM_TIMING; TIM_InitStructure.TIM_Clock_Source = TIM_CLK_APB; TIM_InitStructure.TIM_Prescaler = 0xFFFF; TIM_InitStructure.TIM_Pulse_Length_1 = 0xFF; TIM_Init (TIM2, &TIM_InitStructure); //TIM_ITConfig(TIM2, TIM_IT_TO, ENABLE); TIM_ITConfig(TIM2, TIM_IT_TO, ENABLE); TIM_ITConfig(TIM2, TIM_IT_OC1, ENABLE); //Delay(0xFCD); GPIO_WriteBit(GPIO9, GPIO_Pin_1, Bit_SET); //GPIO_WriteBit(GPIO9, GPIO_Pin_1, Bit_RESET); TIM_CounterCmd(TIM2, TIM_START); } void TIM2_IRQHandler(void) { TIM_ClearFlag(TIM2, TIM_FLAG_TO); GPIO_WriteBit(GPIO9, GPIO_Pin_1, Bit_RESET); VIC0->VAR = 0; /*Acknowledge Interrupt */ // VIC1->VAR = 0; }
you need either
or
normally - not both. if you use TIM_IT_OC1, you can determine the overflow period by 'TIM1->OC1R' and the system's prescalars.
another thing: don't you want to flip the bit to make your LED blink?
GPIO_WriteBit(GPIO9, GPIO_Pin_1, Bit_RESETM);
like this:
status ~= status ; GPIO_WriteBit(GPIO9, GPIO_Pin_1, status);
where 'status' is of type unsigned char, and set to 0 at startup?
thanks dude I got the solution nice reply
