Using the MCB2300 board, I am working with the UART1 interrupt mode. Using a sample program in flash, everything works correctly, but when trying to run the same program at RAM_MODE, I had the following problems: First LPC2300.S changed so called correctly from RAM Vic Vector Address:
LDR PC, IRQ_Addr ; LDR PC, [PC, #-0x0120] ; Vector from VicVectAddr LDR PC, FIQ_Addr Reset_Addr DCD Reset_Handler Undef_Addr DCD Undef_Handler SWI_Addr DCD SWI_Handler PAbt_Addr DCD PAbt_Handler DAbt_Addr DCD DAbt_Handler DCD 0 ; Reserved Address IRQ_Addr DCD IRQ_Handler FIQ_Addr DCD FIQ_Handler VIC_Addr DCD 0xFFFFFF00 Undef_Handler B Undef_Handler SWI_Handler B SWI_Handler PAbt_Handler B PAbt_Handler DAbt_Handler B DAbt_Handler IRQ_Handler LDR R5,VIC_Addr LDR PC,[R5] FIQ_Handler B FIQ_Handler
Despite this, and although called correctly IRQ routine, the return is not working properly, to the point of interruption once. In the program in flash, everything works correctly, but RAM_MODE not load the return address in R14 (LR).
Has anyone had a similar problem or know because this happens?
(I don't know much about this.)
I guess the below is your IRQ_Handler.
As per infocenter.arm.com/.../index.jsp
2.8.5. Interrupt request
The Interrupt Request (IRQ) exception is a normal interrupt caused by a LOW level on the nIRQ input. IRQ has a lower priority than FIQ, and is masked on entry to an FIQ sequence. As with the nFIQ input, nIRQ passes into the core through a synchronizer.
Irrespective of whether exception entry is from ARM state or Thumb state, an IRQ handler returns from the interrupt by executing:
SUBS PC,R14_irq,#4
After some checks and tests, now I know that KEIL already does these for programmers.
Sorry for my mistake.
Thank you for your help,
but the problem is that when the program run in flash, the return from de interruption rutine is OK because R14 have the return address OK. In RAM_MODE R14 have a value like 0x000015C when the program jump to the interruption rutine.
Sorry but I do not understand the commentary.
Since you were doing "Debug in RAM", I guess you did a Memory re-mapping.
And though what you use is a MCB2300, not a ATMEL MCU, but maybe, you encounter some Debugger problems.
"When the remapping is done before ULINK can stop the device, you will see swapped memory areas in the debugger and the CPU may not behave correctly."
Please take a look for the below URL: http://www.keil.com/support/docs/2963.htm
When testing programs in RAM (by modifing the PC), the device may still execute existing code in the on-chip Flash ROM. Therefore it is important that you erase the Flash or program an endless loop into the on-chip Flash ROM.
http://www.keil.com/support/docs/2767.htm
I've done what you say, but I'm the problem, even now with remap and RAM_MODE or jump to interrupt routine, which by the way I use the UART1. On the other hand, do I have to execute the change on the next LPC2300.s line when work in RAM_MODE?
For what reason don't work the IRQ in RAM_MODE?
After various tests, I checked what the error. The variables REMAP and RAM_MODE were in tab C/C++ and not in the ASSEMBLER. I thought that by implementing the program in C was where the variables should be for remapping.
Thank you very much for you help.
