Under Flow -> system crash
Hi.
I am working with a LPC2388 and using the RTX.
I have 6 task and 2 interrupt running at the same time.
Everything is working fine, until the system crashes. The time from power-on until it stops working is not the same.
When I use my ULINK debugger I get "under flow" to one of the task that is running.
I have tried to increase the size of the stack in the interrupt mode, but getting the same result.
Has any one a good idea to solve my problem or had the same problem?
  • When I use my ULINK debugger I get "under flow" to one of the task that is running.
    Well, if one of your stacks really underflows, then increasing its size will definitely not fix the problem - ever.
    A stack underflow indicates that there is a fundamental problem with the code - it attempts to remove more elements from the stack than it put on the stack.
