I2C Busy Busy detection
I'm implementing I2C Multi-Master/Slave mode handling in the LPC2132 chip. I have few queries about the LPC213x's I2C controller operations.
The user manual says that if the is SI bit (serial interrupt) is cleared or if the I2CSTAT is 0xF8, then there is no activity in the bus.
1. Should the master be polling for this status before initiating a start condition and before every other transaction?
2. Should the software implement an explicit locking mechanism to ensure that the transaction is not interleaved? For instance there could be delays between two bytes (induced by software) in a particular I2C transaction by a master and this should not be interpreted as a 'no serial transaction' by another master. This would allow the other master to snoop the bus while a transaction is already proceeding.
3. If explicit locking must be done in software, how could the controller being in Master mode sense the START/STOP condition driven by other masters?
Thanks in advance.
  • Hi,
    here you find some infos on I2C: www.i2c-bus.org/.../.
    1. yes, you will have to do this - look to the link
    2. you will not have to block the bus, because another I2C master will have to wait for stop condition in order to start a new transaction - so you must be sure, that all masters are multi-master-able
    3. this is not allowed - look to the link
  • Hi Stefan,
    Thanks for the info. In case if the other master has to wait for the STOP condition generated in the bus, it can only do so by checking if the bus is already busy right?
    The LPC2132 user's manual does not explicitly mention about the bus busy bit which is asserted when the controller detects a START condition on the bus and is de-asserted upon detecting a STOP condition. Instead, it gives a provision to see if there are serial transactions by polling the I2CSTAT register.
    I had a scenario where two such LPC2132 masters are in I2C bus and they happen to communicate at almost the same time a third slave. In this case, one of the master interrupts the transaction of the other. The I2CSTAT is being polled for determining if the bus is busy. So, just wanted to know if i'm missing out something in terms of the I2C controller available with LPC2132 micro-controller.
    Thanks in advance.
  • I don't know your I2C controller, but if you use a hardware implementation, this hardware must support multi master I2C. In this case, the hardware should handle multi master access to the I2C lines.
    If your hardware does not support multi master, you should think about a software implementation.
  • Stefan,
    Thanks for the info. I rechecked the implementation and found that i was missing to handle Arbitration lost in certain parts of the transaction that resulted in the interleaving of data bytes.
  • Hi there, please mark a reply as a suggested or accepted answer if you feel that your question has been answered. Many thanks!
