hello, I am developing a cypress FX2 firmware to interface it with FIFO in FPGA. iam using GPIF master mode. I have downloaded cyconsole to test my firm ware . i have generated the control signals using the GPIF tool. i am able todownload the firm ware and check the statue of the FIFO , GPIF ( for idle ) and EP2 (out) using the vendor commands . when a send the data from tnehost to EP2 for triggering a write transation , the statue of EP2 is notempty which means there is some data . the atatue of the FIFO is empty and Gpif status is idle . but when i read the GPIFTRIG status it is not triggered for thewrite transation. so write cycle is not initiated . iamnot able to write data into my FIFO. all the conditions are satisfied andthen also the GPIF is not trigerred for fifo write . can any one help? the firm ware also contains the coding for triggering . HERE IS THE CODING IN KEIL C
void TD_Init(void) // Called once at startup { // set the CPU clock to 48MHz CPUCS = ((CPUCS & ~bmCLKSPD) | bmCLKSPD1); SYNCDELAY; EP2CFG = 0xA0; SYNCDELAY; EP4CFG = 0x00; SYNCDELAY; EP6CFG = 0xE0; SYNCDELAY; EP8CFG = 0x00; SYNCDELAY; FIFORESET = 0x80; SYNCDELAY; FIFORESET = 0x02; SYNCDELAY; FIFORESET = 0x06; SYNCDELAY; FIFORESET = 0x00; SYNCDELAY; EP2FIFOCFG = 0x01; SYNCDELAY; EP2FIFOCFG = 0x11; SYNCDELAY; EP6FIFOCFG = 0x09; SYNCDELAY; GpifInit (); // initialize GPIF registers SYNCDELAY; EP2GPIFFLGSEL = 0x01; // For EP2OUT, GPIF uses EF flag SYNCDELAY; EP6GPIFFLGSEL = 0x02; // For EP6IN, GPIF uses FF flag SYNCDELAY; } void TD_Poll(void) { if( GPIFTRIG & 0x80 ) // if GPIF interface IDLE { if ( ! ( EP24FIFOFLGS & 0x02 ) ) // if there's a packet in the peripheral domain for EP2 { if ( GPIFREADYSTAT&0x02 ) // if the external FIFO is not full EXTFIFONOTFULL { if(enum_high_speed) { SYNCDELAY; GPIFTCB1 = 0x01; // setup transaction count (512 bytes/2 for word wide -> 0x0100) SYNCDELAY; GPIFTCB0 = 0x00; SYNCDELAY; } else { SYNCDELAY; GPIFTCB1 = 0x00; // setup transaction count (64 bytes/2 for word wide -> 0x20) SYNCDELAY; GPIFTCB0 = 0x20; SYNCDELAY; } // Setup_FLOWSTATE_Write(); // setup FLOWSTATE registers for FIFO Write operation // SYNCDELAY; GPIFTRIG = GPIF_EP2; // launch GPIF FIFO WRITE Transaction from EP2 FIFO SYNCDELAY; while( !( GPIFTRIG & 0x80 ) ) // poll GPIFTRIG.7 GPIF Done bit { ; } SYNCDELAY; } } }
thanks punitha
