Hi all you programmer people
I wnder if some kind soul can help me?
I have a project on the go which involves 10 sequencial logic level outputs with presetable times on each of the output pins
I imagine it would be very easy to do with a chip if you know how. Unfortunately I don't know even basic programming so I was hoping that someone would take up the challenge.
I don't know what the times are yet so I would need very simple instructions as to how to set and change them.
Once the correct times are set they never need changing I have access to a programmer so have no problem with the hardware
I know programming is easy but i am very busy and don't have time. Obviously, No doubt I could learn how to do the programming, I simply don't have the time. You people know and like chalenges. here is my chalenge for you.
Thanks for any help
Mike
A) Your request doesn't represent a challenge, other than to understand it. http://projecteuler.net/ would be more of a challenge for a sw developer.
B) You don't have the time, but assume that the people on this list do.
C) If you expect to get - what do you spend your time donating?
D) How can anyone help you when you don't supply a reasonable amount of information?
E) You have a programmer - for what?
F) You don't have a problem with the hardware - we don't even know what hardware it is, so we most definitely have a problem with it.
G) "know programming is easy" Is that why we reject some people who have spent a number of years at university? If it is so easy, how could they fail to be good enough to be acceptable?
H) Why have you taken upon you to do something you admit that you don't have the knowledge for?
It takes some skill and effort to even write a good specification for what you are trying to make, let alone implement it. It takes a professional engineer if you want a quality job. Of course, it can be done in amateur-home-project style, but that's a different story. Anyway, I think you expect a bit too much here.
Thanks for the reply but what I need is 10 separate outputs and as I said I don't have any programming skills, I'm an expert with analogue / audio.
try to start with this one:
www.siliconchip.com.au/.../article.html
from sc 08 2005 .. there are source code which you can see and change and sch too (easy to adapt for your req)
Yes - and there's a list of them here: http://www.keil.com/condb
Now it is v urgent and I need some help now.
Plz send the code to me at:
mick_menda@AT@canibuildit.in
bcoz I do not want spam you must replace the @AT@ with the @. if you do not i Wont get your email.
Is this some kind of a joke? If it is, I don't get it. Is this forum moderated?
...i Wont get your email
this seems to me a concise and clear observation.
"Now it is v urgent and I need some help now."
OK, OK! Settle down. It took me a few minutes longer than I had hoped.
Check mick_menda@AT@canibuildit.in to get the results of your request.
Possibly. Some postings are so borderline strange that they're more likely jokes than not.
No. You don't even need to register. That might be a reason for all the joke postings.
I _so_ hate the lack of registration to this forum. It is impossible to separate the fools from the fools. Some posts are made by fools who believe what they write. Some posts are made by fools who think they are clever to troll around.
"It is impossible to separate the fools from the fools. Some posts are made by fools who believe what they write."
http://www.keil.com/forum/docs/thread12822.asp
here is an event sequencer for you:
1) specify what you need 2) send the spec to several consultants with a request for quote 3) choose a consultant 4) pay the consulatnt 5) receive what you need
But if people write things they don't believe in - wouldn't that be called lying?
Hi everybody which sweetly answered,
sorry for the fast msgs but i type Quickly and you probebly think i Am being Stupid ;)))))
i looked For my email but have not got it yet.
i Will write the file to specify exactely what i Need and give more details.
it is v Urgent and i will give a consultants the money bcoz i do not have the time to do it.
Thanks for the time you have for me today.
