My code is just as simple as below:
static unsigned int xdata user_timer_count[8]; static unsigned int xdata count[8]; void func1() { } void main() { int j; user_timer_count[2] = 1000; count[2] = user_timer_count[2]; while(1) { for(j=0;j<8;j++) { if(count[j]==0) continue; if(count[j]==1) { count[j] = user_timer_count[j]; func1(); continue; } --count[j]; } } }
The question is when I declare count as xdata, my program crashes in a uncertain time later. Even after I press reset button, It doesn't work properly. I have to turn down the power and restart.
when I declare:
static unsigned int count[8];
It seem to worked well. I don't know whether it will crash some longer time later, or it's all right. I'm using Small Momery Model, on-chip ROM and XROM. Who can give me some suggestion?
Is the processor and project configured so that you have any XDATA at the addresses the compiler places your variables?
P89C669 has 768 Bytes on-chip XRAM, from 0x0-0x2FF.
The Memory layout is
XDATA (0x0-0x2FF), HDATA (0x0-0x2FF), EDATA(0x7F0000-0x7F04FF), ECODE (0x800000-0x817FFF), HCONST (0x800000-0x817FFF))
.. set the appropiate SFR bit(s) to enable internal xdata (see the datasheet) in (a local copy of) startup.a51.
It's already set.
startup.a51
; EXTRAM: Enable on-chip XDATA RAM ; When disabled, off-chip XDATA space is accessed ; XDATA access (External XDATA space) ; EXTRAM Val Description ; --- --- ----------- EXTRAM EQU 0; 0 = access on-chip XDATA RAM ; ; 1 = disable on-chip XDATA and access off-chip XDATA space
Is there something else?
I just don't undersatnd why program run well for a while and then crashes.
static unsigned int xdata user_timer_count[8]; static unsigned int count[8];
runs properly but
doesn't.
Did you test that you have RAM there?
