I am using an LPC2106 CPU running at a speed of 10MHz, I would use a timer that counts in periods of 1 microseconds just as the system clock without interruption. I can check the system's a good time when I use a period of 1 millisecond but with 1 microseconds the error is very big, around 40%. Can anyone help me with that?
Best Regards,
Bruno CIn/UFPE Brazil
Sorry, but I don't understand you.
Exactly what are you doing, and how do you notice that you have an error of 40%?
A timer configured to tick with 1MHz (i.e. 1us/tick) will tick with that speed - the only error will be the tolerance of the crystal, i.e. a number of ppm.
Whenever you read the current timer value, you will get the exact value at that time.
If you write a tight loop that constantly reads the timer and prints the result, you will not get a fixed time between each sample because of the random delays produced by for example the RS232 TX interrupt.
In short - the timer will tick with a very precise frequency, but any little extra delay in your program will result in the timer stepping quite a number of extra ticks. With a 1ms timer speed, you will not see this, since 1ms is way longer than the service time of an interrupt.
If I have misunderstood your problem, then I would recommend that you better describe exactly what you are doing, what you are seeing and what you expected you should see.
Ok,
I am still not using a real hardware to perform the measurements. I am using the debugger Keil and comparing the time of IDE with the timer counter. With regard error i saw the following: when the TIMER0 in the window of peripheral is 10 microseconds the program time count of 14 microseconds.
Changed the preescaler so that the tick was from 1 millisecond and when the counter of TIMER0 was on 10 miligundos in the program time of IDE also read a count of 10 milliseconds.
Thank you.
Bruno,
Note that the simulator will not be 100% clock-for-clock exact. The main task of the simulator is to compute identical results as the real processor. Being clock-for-clock correct may affect the simulation times a lot since then the simulator must not only produce the same end results, but must perform a large number of micro-steps or internal logic operations.
And another thing. The simulator doesn't even know all wait states in the real memory or all hidden extra logic in the internal processor busses of the processor.
Use the simulator estimations to get an approximation of number of clock cycles to run a code block. But don't rely on the information as perfect.
Per Westermark,
Thanks for your attention.
Best regards.
