SD_file Example Problem
Problem with MCB2300 board and SD_file example.
Look at Terminal's log:
format
Format Flash Memory Card? [Y/N]
Memory Card Formatted.
Card Label is KEIL
Cmd> fill fill_1.txt 100
File closed.
Cmd> fill fill_2.txt 200
File closed.
Cmd> copy fill_1.txt fill_1.bak
Copy file fill_1.txt to fill_1.bak
3.690 bytes copied.
Failed to open fill_1.bak for writing!
Cmd> dir
File System Directory...
FILL_1.TXT                                         3.690   01.01.2008  12:00
FILL_2.TXT                                         7.490   01.01.2008  12:00
FILL_1.BAK                                         3.690   01.01.2008  12:00
                      3 File(s)                   14.870 bytes
                                              14.790.656 bytes free.
3.690 bytes copied.
Cmd>
Why file copied only first time and after 'DIR' command?
