Retarget _sys_open and disable file buffering
I use the FlashFS and therefore, I have a Retarget.c, in which the most _sys_ functions are programmed to wrap the stdio functions to the flash-fs library.
I like to create a virtual file, for which I also wrap the special functionality with the _sys_ functions in Retarget.c. I defined a reserved name for fopen and I assign a special handle in _sys_open to a file opened with that special name.
For this virtual file, I should disable buffering [setbuf(pF, NULL)]. But the problem is, that setbuf uses the FILE *ptr and not the internal handle. And from inside the retarget wrapper functions, I do not know the FILE *ptr.
I could do
FILE *pF = fopen ("VIRTUALFILE", "r");
setbuf (pF, NULL);
but the problem is, that I like to have an abstraction layer, which does not allow to know at level of fopen, whether it is the special file or not. Yes, I could compare the name first and dependent, I do the setbuf(), but that is not the way an abstraction should work... we should be able to do this in _sys_open, but how?
Thanks in advance for your help! - Adrian
