C167 calculate rotation with Timer 3 and 4
I'd like to calculate the speed of rotation from a conveyor band with a photoelectric sensor (switching frequency=500Hz, response time=1ms).
This sensor is connected to C167 pin 3.6 (T3IN).
The wheel from the band has 8 black colour and 8 white colours and we will get HIGH/LOW through a change from the colours.
First, I'd like to count HIGH-Signal in a certain time and then calculate the rotation speed.
Here is my code, the number always increases, although the band is off.
What did I do wrong?
How should I write the code for the calculating?
WORD T3IMAGE;
void main(){
T3CON = 0x0401;
T3 = 0;
T3IE = 1;
T3IC = 0x61;
T2CON = 0x000D;
T2 = 0;
T2IC = 0x44;
T2R = T3R =1;
IEN = 1;
while(1){
TIMAGE = T2;
set_cursor(20,5);
printf("Counter = %5u", T2);
T3IE = 0;
IEN = 0;
T3R = 0;
T2R = 0;
Thank you very much and sorry for the miserable language
Best regards,
Ciek
  • Hello,
    I have changed the code.
    void main(){
       T3CON = 0x0401;  // 0 010|0 0 0|001 T3OTL=1 Teiler 8*2=16
       T2CON = 0x000D;  // 0 0 0 1|101 Counter, rising edge in T30TL
       T2IC = 0x44;    // T2IE=1 ILVL=1 GLVL=0
       T3 = 0;
       T2 = 0;
       T3R=1;
       IEN=1;
       while(1) {
            set_cursor(13,5);
            printf("Counter = %5u", T3);
            set_cursor(14,5);
    I see now in Terminal, that T3 decrement from 65536 to 0.
    If I start T2 (T2R=1), T2 is always going up.
    How should I program, so that I get the value from counter in 65536 tact?
    Thank you so much.
