I am use the ## as follows
#define ADC_SRV_DEV 1
#define ADCCON(dev, chan, reg) AD##dev##CON##chan##reg
then when I give ADCCON(ADC_SRV_DEV, 1, bits.FORM) = 3; // this is equavalent to AD1CON1bits.FORM = 3;
But for some reason it is taking it as ADADC_SRV_DEVCON1bits
Please help
The issue is regarding a Microchip toolchain.
forum.microchip.com/fb.aspx
The issue is actually a 'C' one rather than one specific to any particular implementation. The comp.lang.c faq has an example of how to achieve what the OP wants.
Unless, of course, the OP's issue is due to a specific problem in the specific implementation...
"The issue is actually a 'C' one rather than one specific to any particular implementation."
All preprocessors are created equal?
But, maybe, some preprocessors are more equal that others...?
No. But all that are unequal to the Keil preprocessors, regarding the issue at hand, are irrelevant anyway, because they're even more off-topic than the OP.
Or, possibly, not:
I've worked on projects where the "native" preprocessor had some limitations, so the preprocessor from a different compiler was used...
One project used the Borland preprocessor to pre-process files for a Microtec compiler.
It isn't. As I said, the issue is actually a 'C' one rather than one specific to any particular implementation. In other words, this is the expected and correct behaviour.
In this context, yes.
