HT640...PINS ERROR??
HI..
i am using ht640 encoder ic for my transmitter circuit.
in the datasheet it is given tat the ic has 10 bits address outputs and 8 bits data output...altho there are only 7 pins for Address/Data...and 11 pins for address...is it ok if i use one of the adrress lines for data??i want to send 8 bits of data...
thanks
