Hello, I developed an emmbedded application for a C167CR-LM. In this application I've some very big data structures stored in internal RAM (IDATA) and some dynamic list managed using malloc and free. For dynamic allocation I define the pool:
unsigned char far equivalence_pool[0x4000]; init_mempool (equivalence_pool, sizeof (equivalence_pool));
In my application there is a IRQ routine on a Timer T6 with a period of 0.5 ms.
In some situations the ILLOPA exception is trapped an the application crashes. It generally happens when many digital input (linked to port P2 pins) are active together.
I tried to increase the user stack with no effect.
Adding 2 calls to printf in the IRQ routine, ILLOPA is not generated.
Have you some suggestions for help me how to investigate this problem?
Testing with Mon166 the trap routines are not available, and using Simulator is too complex cause the hardware and input sequences to generate.
Thanks, Marco
I you sure you are not exceeding the size of IDATA?
Yes, because I know the dimension of my memory and then because building the application the Compiler would generate a warning message on exceeding the size of IDATA. But thi Warning is not present.
Thanks.
could it be that your T6 ISR corrupts something critical for the main loop or another ISR?
Please show the ISR's code.
The routine is too long to print it here.
Therefore it's good because it was part of an old application, ant its the main function in my application.
Thanks to all.
no no no Marco, the fact that is used to work means nothing - maybe there is a hidden bug in it you never encountered? you must post more details to allow further analysis.
Here the 1/4 part of the code:
void Timer6Interrupt(void) interrupt 0x26 using Timer6Bank { UINT i; UBYTE countEnc, gapEnc, cnt; UINT checkRB; bit errRB; long comptime; UINT metaldata; UBYTE ErrScan = 0; // ** MTL ** eventuale errore di scansione matrice UBYTE ErrReset = 0;// ** MTL ** eventuale errore di reset buffer UBYTE ErrEqu = 0; // ** MTL ** eventuale errore di normalizzazione equivalenze UBYTE ErrLab = 0; // ** MTL ** eventuale errore di normalizzazione etichette UBYTE ErrCat = 0; // ** MTL ** eventuale errore di catalogazione etichette UBYTE ErrDel = 0; // ** MTL ** eventuale errore di eliminazione equivalenze // ** NEW ** Calcolo Tempo di Idle StopT1Read = T1; comptime = (long)StopT1Read - (long)StartT1Idle; if ((comptime) < 0) IdleTicks = PERF_TIMER + comptime; else IdleTicks = comptime; // ** NEW ** Ci interessa il minimo Tempo di Idle perche' verra' // trasmesso il suo valore percentuale insieme allo stato // Tale valore viene resettato per le prime 5 ricezioni del // comando STS (transitorio) dopodiche entrera' a regime if (IdleTicks < MinIdleTicks) MinIdleTicks = IdleTicks; // ** NEW ** Calcolo Tempo di Cycle comptime = (long)StopT1Read - (long)StartT1Cycle; if ((comptime) < 0) CycleTicks = PERF_TIMER + comptime; else CycleTicks = comptime; StartT1Cycle = StopT1Read; errRB = 0; // ================== GESTIONE RICERCA METALLI ======================= if (MetalDetection.Enable) { // ************************* CONTATORI ******************************* // Sezione 1 - Ritardi e abilitazioni if (MetalDetection.Encoder == 0xFF) { // Ritardi e campionamenti a tempo for (i = 0; i < MTL_BUFNUM; i++) { // Contatore trigger di attivazione if (MetalCounter[i].StartCount != NO_COUNT) { MetalCounter[i].StartCount--; if (MetalCounter[i].StartCount <= 0) { // printf("\nFine StartCount T su buffer %d\n",i); MetalCounter[i].ReadEnable = 1; MetalCounter[i].Active = 1; MetalCounter[i].Broken = 0; MetalCounter[i].StartCount = NO_COUNT; ErrReset = ResetBuf(i); // Resetto il buffer i } } // Contatore trigger di disattivazione if (MetalCounter[i].StopCount != NO_COUNT) { MetalCounter[i].StopCount--; if (MetalCounter[i].StopCount <= 0) { // printf("\nFine StopCount T su buffer %d\n",i); MetalCounter[i].EndDoc = MetalDetection.SensorsDelay; MetalCounter[i].StopCount = NO_COUNT; } } // Contatore timer di campionamento if (MetalCounter[i].Timer != NO_COUNT) { MetalCounter[i].Timer--; if (MetalCounter[i].Timer <= 0) { // printf("\nFine Timer T su buffer %d\n",i); MetalCounter[i].ReadEnable = 1; MetalCounter[i].Timer = NO_COUNT; } } // Contatore bit di dato valido if (MetalCounter[i].CountValid != NO_COUNT) { MetalCounter[i].CountValid--; if (MetalCounter[i].CountValid <= 0) { // printf("\nFine CountValid T su buffer %d\n",i); MetalCounter[i].Valid = 0; MetalCounter[i].CountValid = NO_COUNT; // Abilitazione invio report LENTO1 MetalDetection.SendRepEnable = 1; } } } // for (i = 0; i < MTL_BUFNUM; i++) - Tempo }//to be continued
Here the 2/4 part of the code:
... // Ritardi e campionamenti a spazio countEnc = ENCPORT[0]; for (i = 0; i < MTL_BUFNUM; i++) { // Contatore trigger di attivazione if (MetalCounter[i].StartCount != NO_COUNT) { gapEnc = abs(countEnc - MetalCounter[i].EncPrev); if (gapEnc > MAX_GAP) { // l'encoder e' passato per lo zero // Calcolo il decremento interpretando la direzione di // conteggio dell'encoder MetalCounter[i].StartCount -= (countEnc > MAX_GAP) ? (0xFF - countEnc + MetalCounter[i].EncPrev) : (0xFF + countEnc - MetalCounter[i].EncPrev); } else MetalCounter[i].StartCount -= gapEnc; if (MetalCounter[i].StartCount <= 0) { // printf("\nFine StartCount su buffer %d\n",i); MetalCounter[i].ReadEnable = 1; MetalCounter[i].Active = 1; MetalCounter[i].Broken = 0; MetalCounter[i].StartCount = NO_COUNT; ErrReset = ResetBuf(i); // Resetto il buffer i } } // Contatore trigger di disattivazione if (MetalCounter[i].StopCount != NO_COUNT) { gapEnc = abs(countEnc - MetalCounter[i].EncPrev); if (gapEnc > MAX_GAP) { // l'encoder e' passato per lo zero // Calcolo il decremento interpretando la direzione di // conteggio dell'encoder MetalCounter[i].StopCount -= (countEnc > MAX_GAP) ? (0xFF - countEnc + MetalCounter[i].EncPrev) : (0xFF + countEnc - MetalCounter[i].EncPrev); } else MetalCounter[i].StopCount -= gapEnc; if (MetalCounter[i].StopCount <= 0) { // printf("\nFine StopCount su buffer %d\n",i); MetalCounter[i].EndDoc = MetalDetection.SensorsDelay; MetalCounter[i].StopCount = NO_COUNT; } } // Contatore timer di campionamento if (MetalCounter[i].Timer != NO_COUNT) { gapEnc = abs(countEnc - MetalCounter[i].EncPrev); if (gapEnc > MAX_GAP) { // l'encoder e' passato per lo zero // Calcolo il decremento interpretando la direzione di // conteggio dell'encoder MetalCounter[i].Timer -= (countEnc > MAX_GAP) ? (0xFF - countEnc + MetalCounter[i].EncPrev) : (0xFF + countEnc - MetalCounter[i].EncPrev); } else MetalCounter[i].Timer -= gapEnc; if (MetalCounter[i].Timer <= 0) { // printf("\nFine Timer su buffer %d\n",i); MetalCounter[i].ReadEnable = 1; MetalCounter[i].Timer = NO_COUNT; } } // Contatore bit di dato valido if (MetalCounter[i].CountValid != NO_COUNT) { gapEnc = abs(countEnc - MetalCounter[i].EncPrev); if (gapEnc > MAX_GAP) { // l'encoder e' passato per lo zero // Calcolo il decremento interpretando la direzione di // conteggio dell'encoder MetalCounter[i].CountValid -= (countEnc > MAX_GAP) ? (0xFF - countEnc + MetalCounter[i].EncPrev) : (0xFF + countEnc - MetalCounter[i].EncPrev); } else MetalCounter[i].CountValid -= gapEnc; if (MetalCounter[i].CountValid <= 0) { // printf("\nFine CountValid su buffer %d\n",i); MetalCounter[i].Valid = 0; MetalCounter[i].CountValid = NO_COUNT; // Abilitazione invio report LENTO1 MetalDetection.SendRepEnable = 1; } } // La lettura attuale diventa lettura precedente // per il prossimo interrupt da Timer6 MetalCounter[i].EncPrev = countEnc; } // for (i = 0; i < MTL_BUFNUM; i++) - Spazio } // Fine Sezione 1 - Ritardi e abilitazioni //to be continued
That ISR is very seriously broken. It is many, many, many times too large and tries to do things a 0.5ms ISR should not try to do.
Do split your code into ISR to collect events and a main loop that process the events. Your ISR shouldn't be larger than what you can view at the same time without selecting a microscopic font.
How have you made sure that for any sequence of input stimuli, your ISR manages to do all work in 0.5ms? If y ou can't guarantee that - why even bother to have the code in the ISR if it isn't critical enough that it _must_ be done within 0.5ms?
Here the 3/4 part of the code:
// ************************* LETTURA SENSORI ************************* // le nuove versioni (VerHw = 1) hanno gli ingressi attivi alti metaldata = (Hw) ? (~P2 & MaskInSpeed) : (P2 & MaskInSpeed); // Shift per isolare solo i sensori (0 e 1 vanno all'encoder, // 2-10 vanno ai sensori, 11 va' al trigger) metaldata = metaldata >> (NInputSpeed - 9 - 1); metaldata &= 0x01FF; // Interpretazione ingressi tramite polarity metaldata ^= MetalDetection.SensorsPolarity; // ***************** SCANSIONI RICERCA METALLI ********************** // Sezione 2 - Scansione documento e matrice for (i = 0; i < MTL_BUFNUM; i++) { if (MetalCounter[i].ReadEnable) { if (MetalCounter[i].EndDoc == NO_ENDDOC) { // Salvo sulla matrice di scansione la prima barriera di sensori ScanMatrix[i][0][ScanDoc[i].TotCol] = metaldata & 0x0001; ScanMatrix[i][2][ScanDoc[i].TotCol] = (metaldata >> 2) & 0x0001; ScanMatrix[i][4][ScanDoc[i].TotCol] = (metaldata >> 4) & 0x0001; ScanMatrix[i][6][ScanDoc[i].TotCol] = (metaldata >> 6) & 0x0001; ScanMatrix[i][8][ScanDoc[i].TotCol] = (metaldata >> 8) & 0x0001; if (ScanDoc[i].TotCol >= MetalDetection.SensorsDelay) { // if (ScanDoc[i].TotCol == MetalDetection.SensorsDelay) // printf("\nStart lettura seconda barriera su buffer %d\n",i); // Salvo sulla matrice di scansione la seconda barriera di sensori ScanMatrix[i][1][ScanDoc[i].TotCol - MetalDetection.SensorsDelay] = (metaldata >> 1) & 0x0001; ScanMatrix[i][3][ScanDoc[i].TotCol - MetalDetection.SensorsDelay] = (metaldata >> 3) & 0x0001; ScanMatrix[i][5][ScanDoc[i].TotCol - MetalDetection.SensorsDelay] = (metaldata >> 5) & 0x0001; ScanMatrix[i][7][ScanDoc[i].TotCol - MetalDetection.SensorsDelay] = (metaldata >> 7) & 0x0001; // Analizzo la colonna appena completata per identificare le regioni ErrScan = ScansioneMatrice(i, ScanDoc[i].TotCol - MetalDetection.SensorsDelay); } if (++ScanDoc[i].TotCol == MTL_SCAN_COLS) { // Ho superato la dimensione massima del buffer: chiudo la scansione // documento abilitando la lettura solo della seconda barriera // printf("\nRaggiunto limite su buffer %d\n",i); MetalCounter[i].EndDoc = MetalDetection.SensorsDelay; MetalCounter[i].Broken = 1; MetalCounter[i].StopCount = NO_COUNT; } // Inizializzo il contatore per la prossima scansione MetalCounter[i].Timer = MetalDetection.Timing; } else // if (MetalCounter[i].EndDoc == NO_ENDDOC) { // Siamo a fine documento: completo la lettura salvando sulla // matrice di scansione solo la seconda barriera di sensori ScanMatrix[i][1][ScanDoc[i].TotCol - MetalDetection.SensorsDelay] = (metaldata >> 1) & 0x0001; ScanMatrix[i][3][ScanDoc[i].TotCol - MetalDetection.SensorsDelay] = (metaldata >> 3) & 0x0001; ScanMatrix[i][5][ScanDoc[i].TotCol - MetalDetection.SensorsDelay] = (metaldata >> 5) & 0x0001; ScanMatrix[i][7][ScanDoc[i].TotCol - MetalDetection.SensorsDelay] = (metaldata >> 7) & 0x0001; // Analizzo la colonna appena completata per identificare le regioni ErrScan = ScansioneMatrice(i, ScanDoc[i].TotCol - MetalDetection.SensorsDelay); // Decremento il contatore di fine documento MetalCounter[i].EndDoc--; if (MetalCounter[i].EndDoc) { //to be continued
Here the 4/5 part of the code:
// Continuo la chiusura lettura documento ScanDoc[i].TotCol++; // Inizializzo il contatore per la prossima scansione MetalCounter[i].Timer = MetalDetection.Timing; } else { // printf("\nFine scansione su buffer %d\n",i); // La scansione del documento e' terminata MetalDetection.LastRead = i; ScanDoc[i].TotCol -= (MetalDetection.SensorsDelay - 1); MetalCounter[i].Active = 0; MetalCounter[i].EndDoc = NO_ENDDOC; MetalCounter[i].Timer = NO_COUNT; MetalCounter[i].EquEnable = 1; MetalDetection.BufAvailable = 1; // Viene aggiornato lo stato della scheda secondo lo // stato della memoria di allocazione dinamica, ma non // viene generato un report dello stato slave, pertanto // il nuovo stato verra' trasmesso al primo invio // programmato if (ErrMemory) { Stato |= ERROR_MTL; } else { Stato &= ~ERROR_MTL; } } } // if (MetalCounter[i].EndDoc == NO_ENDDOC) // Disabilito la lettura sensori MetalCounter[i].ReadEnable = 0; } //if (MetalCounter[i].ReadEnable) } // for (i = 0; i < MTL_BUFNUM; i++) // **************** ELABORAZIONI RICERCA METALLI ********************* for (i = 0; i < MTL_BUFNUM; i++) { // Sezione 3 - Normalizzazione equivalenze if (MetalCounter[i].EquEnable) { MetalCounter[i].EquEnable = 0; ErrEqu = NormalizzaEquivalenze(i); MetalCounter[i].LabEnable = 1; // printf("\nNormalizzazione equivalenze eseguita su buffer %d\n",i); } //if (MetalCounter[i].EquEnable) // Sezione 4 - Normalizzazione etichette if (MetalCounter[i].LabEnable) { MetalCounter[i].LabEnable = 0; ErrLab = NormalizzaEtichette(i); MetalCounter[i].CatEnable = 1; // printf("\nNormalizzazione etichette eseguita su buffer %d\n",i); } //if (MetalCounter[i].LabEnable) // Sezione 5 - Catalogazione etichette if (MetalCounter[i].CatEnable) { MetalCounter[i].CatEnable = 0; ErrCat = CatalogaEtichette(i); MetalDetection.LastComplete = i; ErrDel = EliminaEquivalenze(i); printf("\n TotCol per buffer %d = %d\n",i, ScanDoc[i].TotCol); /* printf(" SamplesCount per buffer %d = %d\n",i, ScanDoc[i].SamplesCount); printf(" RegionsCount per buffer %d = %d\n",i, ScanDoc[i].RegionsCount); printf(" NumRegions per buffer %d = %d\n",i, ScanDoc[i].NumRegions); printf(" LargerRegionSamples per buffer %d = %d\n",i, ScanDoc[i].LargerRegionSamples); printf(" HigherRegionHeight per buffer %d = %d\n",i, ScanDoc[i].HigherRegionHeight); printf(" HigherRegionLength per buffer %d = %d\n",i, ScanDoc[i].HigherRegionLength); printf(" LongerRegionHeight per buffer %d = %d\n",i, ScanDoc[i].LongerRegionHeight); printf(" LongerRegionLength per buffer %d = %d\n\n\n",i, ScanDoc[i].LongerRegionLength); */ // Set del bit di dato valido MetalCounter[i].Valid = 1; MetalCounter[i].CountValid = MetalDetection.DlyValid; // Abilitazione invio report LENTO1 MetalDetection.SendRepEnable = 1; // Se la gestione e' a spazio leggo lo stato dell'encoder if (MetalDetection.Encoder != 0xFF) MetalCounter[i].EncPrev = ENCPORT[0]; } //if (MetalCounter[i].CatEnable) } // for (i = 0; i < MTL_BUFNUM; i++) } // if (MetalDetection.Enable) // =============== GESTIONE RICERCA METALLI: FINE ==================== countEnc = ENCPORT[0]; //to be continued
Here the 5/5 part of the code:
// ================== GESTIONE RILETTURA USCITE ====================== if (NOutputSpeed) { if (!RB_Cnt) { // controllo della rilettura di tutte le uscite checkRB = ((~Output) ^ P5) & MaskOutSpeed; for (i=0; i<NOutputSpeed; i++) { if (EnableRB[i] && (checkRB & (1<<i))) { CountErrRB++; errRB =1; } } RB_Cnt = NO_COUNT; } if (RB_Cnt != NO_COUNT) RB_Cnt--; } // ===================== GESTIONE RITARDI =========================== if (NDly) { // gestione canali ritardati for (i=0; i<NDly; i++) { // se nel ciclo precedente è cambiato lo stato dell'uscita viene // controllato se si è verificato un errore di rilettura (se abilitata) if(EnableRB[Dly[i].Output] && (!Dly[i].Status)) { if(((~Output) ^ P5) & (0x0001 << Dly[i].Output)) { CountErrRB++; errRB = 1; } Dly[i].Status = NO_COUNT; } if (Dly[i].Status != NO_COUNT) Dly[i].Status--; if (Dly[i].Encoder == 0xFF) { // -------------- Ritardi a tempo ------------------------------- if (Dly[i].CountDlyOn != NO_COUNT) { Dly[i].CountDlyOn--; if (Dly[i].CountDlyOn < 0) { Output |= (0x0001 << Dly[i].Output); Dly[i].Status = RB_DELAY; Dly[i].CountDlyOn = NO_COUNT; } } if (Dly[i].CountDlyOff != NO_COUNT) { Dly[i].CountDlyOff--; if (Dly[i].CountDlyOff < 0) { Output &= ~(0x0001 << Dly[i].Output); Dly[i].Status = RB_DELAY; Dly[i].CountDlyOff = NO_COUNT; } } } else { // -------------- Ritardi a spazio (encoder) ---------------------- if (Dly[i].CountDlyOn != NO_COUNT) { cnt = abs(countEnc - countON[i]); if (cnt > MAX_GAP) Dly[i].CountDlyOn -= (countEnc > MAX_GAP) ? (0xFF - countEnc + countON[i]): (0xFF + countEnc - countON[i]); else Dly[i].CountDlyOn -= cnt; // Dly[i].CountDlyOn -= abs(countEnc - countON[i]); countON[i] = countEnc; if (Dly[i].CountDlyOn <= 0) { Output |= (0x0001 << Dly[i].Output) ; Dly[i].Status = RB_DELAY; Dly[i].CountDlyOn = NO_COUNT; } } if (Dly[i].CountDlyOff != NO_COUNT) { cnt = abs(countEnc - countOFF[i]); if (cnt > MAX_GAP) Dly[i].CountDlyOff -= (countEnc > MAX_GAP) ? (0xFF - countEnc + countOFF[i]): (0xFF + countEnc - countOFF[i]); else Dly[i].CountDlyOff -= cnt; // Dly[i].CountDlyOff -= abs(countEnc - countOFF[i]); countOFF[i] = countEnc; if (Dly[i].CountDlyOff <= 0) { Output &= ~(0x0001 << Dly[i].Output); Dly[i].Status = RB_DELAY; Dly[i].CountDlyOff = NO_COUNT; } } } } // attuazione dei canali di uscita SetOut(Output); } // trasmissione su CAN della condizione di errore sul PDO di stato // se si è verificato almeno un errore di rilettura if (errRB && (!(Stato & ERROR_RB))) { T8R = 1; Stato |= ERROR_RB; CAN_MSGOBJ[STATO].msg_ctl = CPUUPD_SET; CAN_MSGOBJ[STATO].msg_cfg = MSG_CFG(1, CANDIR_TRANSMIT, 0); CAN_MSGOBJ[STATO].msg[0] = Stato; CAN_MSGOBJ[STATO].msg_ctl = CPUUPD_CLR & TXRQ_SET; } StartT1Idle = T1; }
This ISR rotine is a quarter of another one in another application for the same boards in the same plant, and it runs always good ...
There are stunt drivers that can drive their cars on two wheels - that doesn't mean that it is good to drive a car with two wheels in the air...
your ISR is miles long. it contains wasteful references to array elements, multiple loops... try what Per suggested: move the whole block outside of interrupt context - put it in a function and call it from your main loop. what happens then? again: the fact that code works means nothing beyond that it does not fail on that hardware, under certain circumstance
