What is the format of the map file generated by the qVision tools for the ARM7? I am using a calibration tool that requires a map file to determine the location of RAM variables in my application and I need to know what format the map file is? Also, is there any utilities (or linker options) to convert the map format into a more generic format that my calibration tool may be able to use?
I am using the Keil 3.22a RV compiler.
I also need to go thru the map file that is generated after building the target.
Few info. i could understand , but its major of areas I still not able to understand. Have Anybudy Any idea from where i can find information related - how to read Map file.
