Flash programing error
Can anybody help me?
I have just designed my board with XC164CS microcontroller and when I program the flash memory through JTAG I get the following error:
Erasing...
Erase Done.
Programming Done.
Contents mismatch at: C00022H  (Flash=9BH  Required=08H) !
What might be the error?
If you need information of my design (hardware, software, etc) I will let you know.
Thank you.
  • Is there no one who could tell me what does this error mean?
  • What it mean - exactly what it says, i.e. a memory mismatch.
    But, the question is why.
    Have you based your design on a reference design?
    Does the reference design have this problem?
    When using JTAG interface, you normally program flash memory by downloading a little help application that performs the job - is your programming algorithm suitable for your flash memory?
    What actions have you taken to verify that your design is correct?
    What actions have you taken to verify that your prototype is correct?
    Have you verifeid all timing?
    Have you verified all supply voltages?
  • I have advanced something.
    I have seen that power supply of the core was incorrect (3V). I have put a 2,5V regulatorand now through JTAG I can program and work every program.
    Nevertheless, my employer wants to program by ASC0, but I don't get it. What migth be the problem? Are well made the connections?
