Hi to all. I have some functions that are called from different ISR and are NOT declared as reentrant. Both functions return BOOL which is typedef as follows:
typedef unsigned char BOOL;
(the code compiled and linked without warnings) Trying to optimize the code, I decided to change this declaration, to see if less code is generated:
typedef bit BOOL;
And I gain some bytes of code. But now, the linker gives L15 Warning:
*** WARNING L15: MULTIPLE CALL TO SEGMENT SEGMENT: ?PR?_DPM_RELEASEBLOCK?DPM_ACCESS_FUNCTIONS CALLER1: ?PR?EXTINT_IRQ_HANDLER?MAIN CALLER2: ?PR?TIMER2_IRQ_HANDLER?MAIN
Why this warning was not issued before? The compiler did not inline those calls (they are in different modules) and I checked the assembler code. How is related the bit declaration in the return type with the linker warning?
Thanks a lot.
Take a look at http://www.keil.com/support/docs/805.htm and at the description in the manual of the call tree and how it works at http://www.keil.com/support/man/docs/bl51/bl51_ol_calltree.htm.
Jon
Thanks for the info. I did know that the compiler warning was due to the reentrancy of the functions. This problem does not bother me, because I can (and I think it's a better idea) move the code that calls to the functions to the main loop, and set a volatile flag in each ISR. Then the reentrancy disappears.
I am only curious about the fact that the linker did only complaint when I changed the return type, from unsigned char to bit.
Is there a good reason to do that? I already know that functions with bit parameters nor return types cannot be declared reentrant, and that makes sense. But the fact is that they weren't!
Thanks anyway.
