I am coding a c++ wrapper to listen messages coming from the CAN bus for an ARM7 processor, and need to launch a task for callback function. I define the callback function as static as usual when using threads. When compiling the following error appears:
error: #167: argument of type "void (*)(void*)" is incompatible with parameter of type "void (*)(void *) C"
What am i doing wrong? It is possible to launch a task inside a class?
Source code sample:
void taskCallBack( void* pthis ) __task; class BusCAN { public: CAN_ERROR start( bool listen ); virtual void onMessage( CAN_msg *msg ) = NULL; private: static void taskCallBack( void* pthis ) __task; // ... }; CAN_ERROR BusCAN::start( bool listen ) { CAN_ERROR canError = CAN_start( CANCtrl ); os_tsk_create_ex( taskCallBack, listenPriority, this ); return canError; } void taskCallBack( void* pthis ) __task { CAN_msg msg_rece; for (;;) { // Do something } }
Thanks in advance.
is the
taskCallBack
with the infinite loop the same that you refer to earlier? if so, why then doesn't the definition look like this:
void BusCAN::taskCallBack( void* pthis ) __task
did you check the prototype of
os_tsk_create_ex
? are you sure it can accept a member function...?
Thanks for the answer, and sorry, you're right: the source code is incomplete.
At the moment, I tried with three posibilities:
1.- As member function, my first try (but os_tsk_createXXX does not accept member functions, that was the expected behaviour).
void BusCAN::taskCallBack() __task
2.- As static member function: message error: "error: #167: argument of type "void (*)(void*)" is incompatible with parameter of type "void (*)(void *) C"
static void BusCAN::taskCallBack( void* pthis ) __task
3. As friend function of the BusCAN class: same error message as above.
My experience with this come from using POSIX threads into classes, and the easiest workaround was using static member functions to define thread behaviour. I think this is a similar case.
Hope this helps to show what I am trying to do. Thanks.
