I have some problems with configuration of CAN1 baud rate setting in LPC2378. This is the code section that configure CAN1 controller. Mind that CPU clock frequency CLK is 72 MHz .
void start_an_network(unsigned long can_btr){ unsigned long dummy; // CAN controller 1 dummy = CAN1ICR; // reset interrupt flag CAN1MOD |= 1; // reset can controller // Set peripheral clock PCLKSEL0 &= ~(3 << 26); // CLK / 4 = 72/4 = 18 MHz // PCLKSEL0 |= (1 << 26); // CLK / 1 = 72/1 = 72 MHz // PCLKSEL0 |= (2 << 26); // CLK / 2 = 72/2 = 36 MHz // Enable clock to the peripheral PCONP |= PCAN1; // port configuration PINSEL0 &= ~0x00000F0F; PINSEL0 |= 0x0000005; CAN1IER = 0; // Disable Receive Interrupt CAN1GSR = 0; // Reset error counter CAN1BTR = can_btr; // baud rate setting CAN_AFMR = 0x02; // by pass mode CAN1MOD = 0x0; // CAN in normal operation mode // irq configuration follows... }
If I configure peripheral clock frequency to 72/4 MHz, messages are transmitted and received correctly. However I cannot configure CAN controller baud rate to 800 kbit/s because of time quantization. Therefore I have tried to set peripheral clock frequency to 72 MHz and then to set baud rate to 1000 kbit/s using
can_btr = 0x00270005 or can_btr = 0x003C0003
In this case I've seen through debugger that after the execution of the instruction
CAN1BTR = can_btr;
the value into CAN1BTR register is always 0!
After that I've tried to set peripheral clock frequency to 72/2 MHz and CAN baud rate to 1000 kbit/s using
can_btr = 0x00270002 or can_btr = 0x003C0001
In this case I've seen that the value is correctly written into CAN1BTR register, however messages emitted by CAN controller are not correct (I've controlled them with a CAN analyzer and with an oscilloscope).
Have you ever seen such troubles like these ones? Have you ever any suggestion?
Thank you,
Demis
I got into troubles if the PCLK_ACF setting was different from the PCLK_CAN1 and/or PCLK_CAN2 setting. Then some register writes "magically" failed.
Thank you a lot!!! I've added the configuration of PCLK_ACF and now all seems to work properly both at 72 MHz and 36 MHz.
Thank you very much!
Have a nice day!
Happy to be able to help :)
I spent a lot of time with this little problem :/
