STR9 + RealView: Absolute placement of the startup code
I want to place my startup code at different absolute locations to support a bootloader. I was hoping that the RealView assembler will allow something like the below code snippet, that works for the STR7 with a Keil compiler:
AREA   STARTUPCODE, CODE, AT CODE_BASE
this piece of code in the startup file is followed by the vector table, where CODE_BASE is the desired address.
I checked the latest RealView assembler documentation but it seems that AREA does not support this anymore (which explains my compile time errors...).
Do you know how this can be done?
