debugging error.
Hi all
I have just started to use AT91sam9260 in keil 3.5v
When i write a simple prog... the compilations gives no errors. When I start debug it displays
"Error 65: access violation at 0xFFFFEE40: no 'write' permission"
I checked the previous posts and tried to change the memory address locations in Target options. Still it gives the same error. I am facing this problem only with ARM-9series. ARM-7 is working fine
plz help me to solve with this problem.
Thanks in advance
sriram
