Does anybody know such a (preferably simple) tool that would allow an automated creation of a list of all used function related to some particular module in a project. For example, I have a project
\MyProject \module1.c \module2.c \module3.c ... \moduleN.c
where e.g. moduleX.c has functions like:
functionA(...) functionB(...) ... functionQQ(...)
declared somewhere.
I want to see which particular functions were ever called from my application - a tool may use either map or assembly generated listing or (??) for parsing analysis.
Ideally this tool should work like this:
a_parsing_tool.exe <my-some-form-of-entire-application> <c_module_in_interest (e.g. module3.c)>
which gives output like:
the function1() was called 2 times the function2() was never called the functionY() was called 74 times ...
Information about statistics may be dropped off but the tool needs to be a stand-alone application running ideally from the command line.
Any idea?
Regards, Nikolay.
"grep"?
No: grep just shows that the text appears in the file - it doesn't show if it was an actual call or, if it was, what function made the call.
The uVision Code Browser shows you this information interactively
but there is still no way to export it from uVision.
Thanks,
I realize it is off-topic but: would Perl script worth to look for? - I.e. any idea how much efforts would it require, any idea? Maybe someone has a script ready to use for a similar requirements...
What about cscope?
http://cscope.sourceforge.net/ cscope.sourceforge.net/cscope_man_page.html
The man page says it builds a cross-reference. Maybe the format of cross-reference is simple enough to extract the data you need with grep/awk/perl/etc?
