Hi , I am looking for the code for uart0 for STR9 in which wnen ever I send some character form the terminal it should just jump to the interrupt handler print taht character then come back can any one please help it should be like this
#include "91x_lib.h" #include "stdio.h" #include <91x_lib.h> #include <string.h> #include <limits.h> u16 LedPulse = 0,tmp = 0; GPIO_InitTypeDef GPIO_InitStructure; static unsigned int tx_restart = 1; /* NZ if TX restart is required */ void UART0_IRQHandler(void); void com_baudrate (unsigned int baudrate) { unsigned long BRDi = 0, BRDf = 0; unsigned long long UARTClk = 48000000; if ((SCU->CLKCNTR & SCU_BRCLK_Div2) != SCU_BRCLK_Div2) { UARTClk /= 2; /* set UART Clock acc. BRSEL */ } /* baudrate calculation */ BRDi = ((100 * UARTClk) / (16 * baudrate)); /* calculate the integer part */ BRDf = BRDi - (100 * (BRDi / 100)); /* calculate the fractal part */ UART0->CR &= 0xFFFE; /* disable UART */ UART0->IBRD = BRDi / 100; /* set the integer part */ UART0->FBRD = ((((BRDf * 64) + 50) / 100)); /* set the fractal part */ UART0->LCR &= 0xFFFF; /* to accept baudrate */ UART0->CR |= 0x0001; /* enable UART */ } int SendChar (int ch) { UART_SendData(UART0, ch); while(UART_GetFlagStatus(UART0, UART_FLAG_Busy) != RESET); return (ch); } int GetKey (void) { while ((UART0->FR & 0x10)); /* RX Fifo Empty */ return (UART0->DR); } void com_initialize (void) { /*------------------------------------------------ Setup serial port registers. ------------------------------------------------*/ UART0->LCR = UART_WordLength_8D /* 8 bits */ | UART_Parity_No /* no Parity */ | UART_HardwareFlowControl_None /* no flow control */ & UART_StopBits_1 /* 1 Stop bit */ & UART_FIFO_Disable; /* FIFO disabled */ UART0->CR = UART_Mode_Rx /* Receive Enable */ | UART_Mode_Tx /* Transmit Enable */ | 0x0001; /* UART Enable */ // UART0->IMSC = UART_IT_Transmit /* Enable Tx Interrupt */ // |UART_IT_Receive ; /* Enable Rx Interrupt */ UART0->IMSC = UART_IT_Receive ; /* Enable Rx Interrupt */ com_baudrate (115200); /* 115200 */ /*------------------------------------------------ Setup Default Interrupt ------------------------------------------------*/ //VIC0->DVAR = (unsigned int)def_irq; //VIC1->DVAR = (unsigned int)def_irq; /*------------------------------------------------ Setup UART0 Interrupt, UART0_ITLine = 16 ------------------------------------------------*/ // VIC1->VAiR[3] = (unsigned int)UART0_IRQHandler; /* set IRQ handler */ // VIC1->INTSR &= ~(0x01 << (UART0_ITLine - 16)); /* generate an IRQ interrupt */ ///VIC1->VCiR[3] = 0x20 | (UART0_ITLine - 16); /* enable vetored interrupt No 0 */ //VIC1->INTER |= (0x01 << (UART0_ITLine - 16)); /* enable the interrupt */ SCU_AHBPeriphClockConfig(__VIC,ENABLE); SCU_AHBPeriphReset(__VIC,DISABLE); VIC_DeInit(); VIC_Config(UART0_ITLine, VIC_IRQ, 0); VIC_ITCmd(UART0_ITLine, ENABLE); } void LEDINIT() { GPIO_DeInit(GPIO9); GPIO_InitStructure.GPIO_Direction = GPIO_PinOutput; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1 ; GPIO_InitStructure.GPIO_Type = GPIO_Type_PushPull ; GPIO_Init (GPIO9, &GPIO_InitStructure); GPIO_WriteBit(GPIO9, GPIO_Pin_0, Bit_RESET); GPIO_WriteBit(GPIO9, GPIO_Pin_1, Bit_RESET); } void main(void) { SCU_APBPeriphClockConfig(__GPIO9, ENABLE); LEDINIT(); SCU->GPIOIN[5] = 0x0002; SCU->PCGR1 |=0x8; SCU->GPIOOUT[5] = 0x03; /* P5.1 input UART0 RX */ SCU_APBPeriphReset(__UART0,ENABLE); SCU_APBPeriphReset(__UART0,DISABLE); com_initialize(); GPIO_WriteBit(GPIO9, GPIO_Pin_0, Bit_SET); while(1) { if(tmp>0) {// Delay(0xFFF); // printf("."); //GPIO_WriteBit(GPIO9, GPIO_Pin_0, Bit_RESET); //GPIO_WriteBit(GPIO9, GPIO_Pin_1, Bit_RESET); //tmp=0; } //tmp=0; } //tmp=0; } void UART0_IRQHandler(void) { volatile unsigned int IIR; unsigned char ch; //tmp++; while ((IIR = UART0->MIS) & (UART_IT_Transmit | UART_IT_Receive)) { if (IIR & UART_IT_Receive) { UART0->ICR = UART_IT_Receive; /* clear the interrupt */ GPIO_WriteBit(GPIO9, GPIO_Pin_0, Bit_SET); printf("%c",ch); } } GPIO_WriteBit(GPIO9, GPIO_Pin_1, Bit_SET); VIC1->VAR = 0; /* Acknowledge Interrupt */ } </p> what happened in this code is that uart does not comes out from the handler what may be reason i am not able to get
